Door seals
My dealer told me he changed the door seals, as a result of a complaint I had that I hear some noise in front doors when passing bumps.
However, I tried to visually check what is new, and I cannot notice anything changed in rubber on front doors.
Are these door seals something inside where I cannot see? The noise is much proeminent than before, and I will return tomorrow to chat with them. Any ideea on what to check before to make sure they changed anything? Anyone has a picture of the much discussed here, door seals?
Originally Posted by EBMCS03' post='236836' date='Feb 8 2006, 10:20 PM
I think theres a little yellow / green round sticker on the new ones.
Here you go.
"Improved door seals can be recognized by the words "EPDM+Polyesterflock" (1) and a yellow dot (2) located on the bottom of the seal."
http://www.bmwtis.com/tsb/bulletins/bullet...mp/B510205g.htm
This is for BMW NA but it could be useful:
SI B 51 02 05
Body Equipment June 2005
Technical Service
SUBJECT
Squeaking Noise from Door Frame Area While Driving
MODEL
E60 (5 Series) produced up to 01/2005
SITUATION
Some customers may complain that they hear squeaking noises coming from the doorframe area while driving.
CAUSE
The movement between the mating surface of the flock covered door seal (felt-like material indicated by the arrows) and the surrounding roof panel produces a squeaking noise.
CORRECTION
In case of a customer complaint, replace all 4 door seals with the improved door seals.
PROCEDURE
Flocking material of the door seal has been improved. Install these improved door seals on all 4 doors of the vehicle.
Notes:
Do not use "Carbaflo" on improved door seals.
The yellow dot is only a temporary indication during stock transition. This yellow dot will not be applied in future production of door seals.
PARTS INFORMATION
Part Number
Description
Quantity
51 21 7 057 507
Left front door seal
Right front door seal
51 22 7 057 509
Left rear door seal
Right rear door seal
WARRANTY INFORMATION
For information only.
[ Copyright ? 2005 BMW of North America, LLC ]
SI B 51 02 05
Technical Service
SUBJECT
MODEL
SITUATION
CAUSE
CORRECTION
PROCEDURE
Notes:
PARTS INFORMATION
Part Number
Description
Quantity
51 21 7 057 507
51 22 7 057 509
Left rear door seal
