Door lock pin lever is clicking/knocking when unlocked
One of my rear doors has a new problem. When I unlock the doors, instead of unlocking in a single click, this one door's pin lever knocks about 2 or 3 times and even then it doesn't pop out completely like the others. The door does unlock but if you looked at the position of the pin you would have thought it was locked. In unlock position its not as low as the lock position but is quite low. I opened the door panel to check if there was anything obviously wrong but can't see anything. Its almost like the door mechanism is playing up. I hope I don't have to take it in. It seems like quite a lot of work to remove or get to the door lock. Any ideas.
