Door airbag
My Ride: BMW F10 528xi
Model Year: 2013
Hello bimmers
My door speaker was broken ( I thought) so removed the door cover. I saw that on the speaker there was a screw. So I take out the screw and the speaker was perfect.
To do this job I had to remove the airbag plug. When plugged in and installed everything back together. I turned on the car and there was the airbag error for the passenger. How can I remove this error?
Thanks
Thanks
Before disconnecting that airbag connector, you were supposed to disconnect battery negative cable.
Take the car to any independent mechanic [or dealer], they will be able to reset the airbag light.
