Doesn't seem like many have 17 offset for the rears
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Originally Posted by BMWSTL' post='445840' date='Jul 10 2007, 02:24 PM
Given the offset difference (12mm vs either 18 or 20mm), will the 12mm offset 166's or 167's M-wheels work on a non-M E60 when you use a 245/35/19 tire (vs the 255/40/19 tire used on the M's), and will there be any issues?
Lou
Lou
Originally Posted by vegastrashed' post='446001' date='Jul 10 2007, 08:36 PM
245/35/19 will work without any problems whatsoever in either 166 or 167 wheels. IMO, the 18mm offset of the 172 wheels puts the wheels to far inset.
Originally Posted by BMWSTL' post='445951' date='Jul 11 2007, 04:44 AM
Thanks for the reply. I'm don't understand why the M wheels would work on the front with 245/35/19 tires. If the smaller offset (12mm) moves the wheel and tire outward, and the recommended tire for a non-M wheel with an 18 or 20mm offset is 245/35/19, wouldn't the same size tire rub when mounted on an M-wheel with a 12mm offset? I must be overlooking something.
Lou
Lou
You need to understand the differance between wheel offsets and tyre diameters.
The 166 and 167 -rims bring out the front WHEEL out some 6mm's / side - that ain't that much.
But the non-M E60's needs the correct TYRE diameter, which is a 245/35 19".
The same goes for the rear tyres.
285/30 19" rears look great and are within the factory given non-M E60 tyre specs.
The M wheels are good for the tyres sizes above.
I strongly recommend that you buy tyres with rim protection!
asinner
05-06-2015 06:03 PM
