Does engine breaking cause damage
Old Jun 27, 2008 | 05:58 AM
beaker's Avatar
Originally Posted by Anzafin' post='611163
Engine braking done right can save lots of fuel.
How exactly? Pushing in the clutch and using the brakes brings the engine to idle. Engine braking ups the RPM. Higher RPM = more fuel used.
Old Jun 27, 2008 | 06:09 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
Nope. Modern fuel injection systems are designed to cut fuel injection when engine braking is noticed.
edit: There's lots of incosistent information about this issue in the web and there can be differencies in fuel injection systems between different manufacturers.
Look at this: Ecodrive.org. Especially "Decelerate smoothly" chapter.
Old Jun 27, 2008 | 06:45 AM
CWS530's Avatar
Gear changes are designed to increase speed, while brakes are designed to slow the car. Downward gear changes should only be used to match the cars's speed/revs for the purposes of acceleration, generally following braking. There are exceptions to this, such as extended steep mountain descent situations where your brakes will overheat, etc., but in general you should slow the car only with the brakes.
Old Jun 27, 2008 | 08:37 AM
s4iscool's Avatar
My Ride: E90 330i + E60 550i
cws530, well said.
Old Jun 27, 2008 | 08:53 AM
beaker's Avatar
If you're staying in the same gear, perhaps. If you're downshifting, no way. The RPMs will go up; if these modern fuel injection systems have figured out a way to up the RPMs and reduce fuel use at the same time, I'd love to hear about it.
Old Jun 27, 2008 | 09:00 AM
Anzafin's Avatar
When engine braking, the wheels/driveline are spinning the engine (RPMs go up), and as a result, the ECU does not see a demand for fuel. Now you've heard .
Old Jun 27, 2008 | 11:49 AM
tprindle's Avatar
My Ride: 2008 535i ALS, Nav, Cold Weather package, Premium package, Logic 7
On my 535i (auto trans) with the cruse control engaged - when I go down a hill and the speed starts to pick up the car will automatically down shift. I know this because the rpms increase. It only appears to shift out of the 6th gear. If the hill is steep enough then the car will apply the brakes to keep the speed at the cruse control set point.
On one occasion going down a long steep hill I manually downshifted again (to the 4th gear) to reduce the amount of time the brakes were being applied.
Old Jun 27, 2008 | 03:20 PM
Palmo's Avatar
My Ride: E60 525d M-Sport Saloon M57N2 3.0d LCI EXTERIOR: Jet Black, ///M-Aerodynamic Bodystyling, ///M-Rear Spoiler, De-badged, Gradual Tint Windscreen, ///M-Double Spoke 172M 19" Alloy Wheels (with non-run flats & space saver spare wheel) & ///M-Sports Suspension; INTERIOR: ///M-Steering Wheel, Black Dakota Leather Heated Sports Seats with Electric Lumbar Supports, Brushed Aluminium Interior Trim & Anthracite Headlining.
With regards using a manual gearbox I completely disagree. With an auto, then you have a point.
Old Jun 27, 2008 | 03:25 PM
Palmo's Avatar
Agree - with modern engines, fuel is cut on the over-run completely, it is the drivetrain turning that allows the revs to increase when changing down a gear not fuel.
Old Jun 27, 2008 | 04:45 PM
zen's Avatar
zen
Check your manual because if you have an auto trans, you may already have automatic braking. It is called HDC (hill decent control).
