Dodged a bullet...thanks to my indy shop
My Ride: '04 545i, sport pkg, premium sound, sprint booster,
Tueseday evening I was about to step out to get something to eat when I noticed a small puddle of coolant under the car. First thought, oh shit now what? I popped the hood and checked the expansion tank, and it was about half full, now that air could get in the tank more coolant started to leak, so I recapped the tank. I thought from where it was leaking it was the thermostat or waterpump. I decided to eat something at home instead and call the indy shop I go to first thing in the morning.
I called the shop and they were totally booked up for the day, but was told to bring it in anyway so they could take a look at it. Lucky for me the shop is only about 9 miles away, so I decided to drive there instead of getting towed. I filled up the expansion tank and was on my way, about two miles from the shop I started getting the low coolant warning. Thankfully I never overheated the engine and I made it to the shop with no problems (lucky).
The shop gave me a ride back home and I waited for a call from Carson the sevice manager. A couple of hours later he called me and told me that the coolant pipe (item 3 in picture) in the engine block had cracked and needed replacement. He then told me that the tech was sure he could replace it through the throttle intake housing. If that didn't work, he would have to take apart the intake manifold. The work was done the next day with no problems. I'm not sure how he did this, but it saves a lot of work hence saved me a boat load of cash. Total cost for labor, parts and tax was $430! I would hate to imagine how much the stealership would rape me for. Kudos to Autoscope Dallas!
Next on the agenda is to replace the thermostat, waterpump and upper and lower hoses. Of course I will not buy these parts locally, its way too expensive. I was also recommended to replace the radiator. Has anyone else had a radiator replaced as part of a preventative maintenance program?
You made out like a bandit! That is the infamous coolant pipe leak that stealers will charge $10k to replace because they require almost complete disassembly of the upper half of the engine. There is a collapsible replacement pipe that has been available for awhile now that reduces the labor required, and thus cost to around $1500. However, you have undercut even that method significantly! Glad I live in the DFW area...gonna keep these guys in mind...
My Ride: 05 545i SMG/Sport/Prem/Nav/HUD/Cold/PDC
04 330ci Sport/Prem/HK/Cold
93 325i Sport/Prem/Cold (Project Car)
I wish this was true. Are you sure it wasn't the short upper return pipe between the water pump and the valley pan. P/N 11511439976 ?
You are talking about the wrong pipe. The one you mentioned is metal with O-rings. This is a major repair and impossible for $500. The part you are likely talking about is the short plastic transfer coolant pipe and is easily replaceable by removing the water pump. #3 in this picture.
![](http://www.realoem.com/bmw/diagrams/r/s/130.png)
Negative. The labor desciption on my receipt states "Replace cooling hose under intake". Parts description, throttle body gasket, vent tube and antifreeze BMW. Impossible? Evidently not. If they were going to replace the pipe your talking about, I would have had both the thermostat and water pump replaced while the work was being done.
Either way its good that you got your ride back running. They are wonderful cars.
If you look at my engine here you can see the line running from one side to the other. This may be your issue.
![](https://sphotos-a.xx.fbcdn.net/hphotos-ash3/s720x720/527126_510974875586786_1296502634_n.jpg)
And to give you an idea you would have required more tear down than this if it was done OEM. Much more. Harmonic balancer, lower timing cover, timing sprockets, gears, chains, oil filter bracket on drivers side, and more.
![](https://sphotos-b.xx.fbcdn.net/hphotos-ash4/s720x720/483382_510065512344389_251458620_n.jpg)
