Do I need my Control Arm Bushings replaced?
Old 03-08-2017, 07:07 PM
JPR10's Avatar
My Ride: 2010 535i M-Sport
Originally Posted by E60Japanese
I just copied them off my receipt without noticing that
I bought a set for $150
they work great
if you want to know the part numbers for your car go to this web site and you can put in the last 7 digits of your body number and then find any part number you want for your car
RealOEM.com - Select Your BMW Model
but you can just buy a set of ebay which is easy
remember when you do it to tighten the bushes under load or you will ruin the bushes real fast
my friend didnt do it and he had to do it again 6 months later
Its a real easy fix so dont be worried about it
Can you explain the best way to load the suspension? Can I use a jack under the front wheel and compress the shock/spring all the way? How did you do it?
Old 03-08-2017, 07:43 PM
JPR10's Avatar
Alright I think I figured it out -- I know which parts to buy... As far as loading the suspension, how far should I jack the car up to ensure that the suspension is properly "loaded"
Old 03-08-2017, 07:48 PM
LessIsMore's Avatar
My Ride: 2009 535i Sport
Model Year: 2009
Engine: N54
Once you get the control arm installed - with the car still on jack stands, use a jack under the ball joint by the hub, and raise it until the wheel is at the height it would be under normal conditions, i.e .car with wheels/tires mounted, on the ground. (The suspension will compress. If the car body starts to rise off the jack stands, you've gone too far up. Lower it back down a bit. ) Then tighten the control arm bolt to torque spec.
Lower the jack to decompress the suspension again, and remove the jack.
Old 03-08-2017, 08:02 PM
E60Japanese's Avatar
My Ride: E60 2006 sedan auto
I have done it two ways
When the car was on stands and the control arms are fitted you can jack the car up with the two bolts going through your bushes lose under your hub or ball joint
Jack the car till the pressure just releases of the jack( just) and then do both bolts up tight
But don't over jack it as already written
The other way is to put the car back on its wheels or car ramps and lay under the car and do them up under normal conditions
One other point is your ball joints
They have a hex fitting in the top
It is important that when you tighten the joint up to always use a hex tool as you can otherwise twist the ball joint rubber and tear it if you don't
Old 03-08-2017, 08:11 PM
Would this suffice for both front axle control arms?
BMW Front Lower Control Arm Kit Left & Right Premium HD E60 (4pcs) | eBay
Or this? Which includes the 4 control arms + sway bar links?
BMW E60 525i 530i 545i 550i NEW 6 Front Control Arm Sway Bar Link 31126774825/81 | eBay
Of course it would be nice to replace the swaybar links at the same time
they go from your sway bar ends to a bracket connected onto your strut mount
The sway bar links maybe okay but if you want a really nice job i would do it all at the same time
I think it was suggested before to also replace your sway bar rubbers
Ill look for a link to show you
Old 03-08-2017, 08:12 PM
Here is a link to show you the swaybar bushes
https://www.ebay.com/itm/300700940330
Old 03-09-2017, 02:38 PM
KyleB's Avatar
My Ride: 530i
Engine: M54
Mileage is about 155k. I doubt they've been done before. I've owned the car 3 months and have done several major repairs including transmission servicing (fluid, pan/filter), disa valve rebuild, and VANOS seals replacement.
I'm in the process of trying to sell the car so the cheapest fix for the clunking would be ideal. I had a buyer back out today for that reason.
If you're at 155K and they've never been done, I can just about guarantee every bushing and ball joint on every control arm is worn out. I'd do all four control arms in the front.
jasondomina (09-28-2023)
