Diversity Antenna - can’t find a specific post
My Ride: 2007 SG/Black E61 | 6MT
Model Year: None
A while back, I read a diy here for a diversity antenna. A posters mentioned that you have one chance to seal the newly replaced diversity amplifier from being water damaged again. I can’t find that post anywhere.
Can someone either point me to that specific post or better yet, explain what needs to be sealed and what sealant to use?
thank you!!
thank you!!
Administrator
Here's a suggestion:
1. Go to the forum menu bar and select Search --> Advanced Search.
2. In the Search by Keyword section , in the Keyword(s) box, type "diversity antenna" in quotes and then "sealant".
3. Leave the Search Entire Posts option.
3. Scroll down and click Search Now.
When I tried it, there were 23 results. Read through those posts. If you don't find the post you're looking for, try some different keywords. Good luck!
Model Year: None
I read through all of those. No joy
Is there such thing as a permanent fix for keeping water out the diversity antenna area?
Administrator
So sorry!
It was worth a shot.
I've moved your post to the E60 General Discussion area where hopefully it will get more exposure.
![Crying](https://5series.net/forums/images/smilies/imported/crying.gif)
My Ride: 530xi 6sp
i think i read that even with a replacement and re-seal of the compartment, water still manages to get in over time. just something you'll have to deal with, i guess.
Engine: N54
I wasn't even aware this was a water related issue.
Engine: N54
vanos
11-25-2014 11:01 AM
msevestre
11-17-2014 12:06 AM
