Difference between older 523i and New 523i facelift
My Ride: BMW 523i Orient Blue, M-Style Aero Kit, 19" M5 wheels
Does anyone know the differences in the engines between the 2008 facelift 523i and the older versions? If they are all the same engine block and same engine capacity, why cant we just remap the ECU to acheive the same bhp as the 525i? Anyone have any ideas?
Simply put: The 2006 model had a 2.5 liter engine with 177 BHP. In the LCI upgrade the engine was overhauled an got a direct injection system managed by a high pressure pump reaching 1800 psi (or is it bar?, I never get that straight) and now has a power output at 190 BHP.
So, the block and capacity is the same, but otherwise a much changed engine.
My Ride: 525d LCI - xenon, tv function,grey dakota leather,titanium silver,244 radial spokes.
Well i don't think it is that easy to just up the ECU.
I think the 525d and 530d share the same engine now so why would anyone buy a 530d if this was possible. Just get a 525d and put a 530d ECU in it, wishful thinking !
My Ride: 2007 E60 LCI 523i delivery 30thNov. 2007
Originally Posted by cablesurge' post='543467' date='Mar 12 2008, 08:36 PM
ok. then would it be possible to install a high pressure pump to replace the exisiting one to boost the bhp or are there many other things that need to be changed? Or is it not as simple as that? Dont think BMW would waste tonnes of money modifying their engines for the same model.
Summary: Iti s possible if you can get the ECU reprogramming done (BMW wont do it) and yes there is no need to change the pump etc for this since the engines are absolutely identical. The new 523 ius rated at 190bhp vs, the older one rated at 177bhp; there are quite a few modification between the old N52 and newer N52K engines, in Europe they use the Direct injection version N53 version with same power rating of 190 bhp. hope this helps.
I do not think you can draw parallels to the diesel engines which are not avaialbe in Singapore anyway....
My Ride: 525 saloon, auto, Silver, artificial leather, USB, 244 wheels
Originally Posted by desertfox65' post='543522' date='Mar 12 2008, 03:57 PM
THe 523 LCI version and the 525 LCI indeed use the same engine N52n ( i.e. N52K) 2.5liter version. the N53 was not released in asia
umnitza
09-02-2015 12:28 PM
