Difference between iDrive High and iDrive Low controllers
Hi guys, can someone tell me what is the difference between the high and low controllers?
As I'm aware the High supports the diagonals in order to navigate thru the map. My core question is, can the LOW controller be used with a Prof Navi for gaining basic functionality, or I need the High in order to get things moving on the screen?
Thank you!
Thank you!
My Ride: 04 545i - Titanium Silver/Black, Sport pkg, Comfort Seats w/ Lumbar, Premium Sound, power rear sunshade, Adaptive Xenon Headlights, Steptronic, Park Distance Control, Fold down rear seats w/ski bag, Aux jack, 6-disk changer, puddle lamps...
Engine: Custom Remus cat-back exhaust w/chrome square tips, K&N Air Filter, Charcoal Filter Removed, Sprint Booster :-), 50/50 mix of 91+100 Octane, EuroRev ECU Remap (coming soon lol), Dinan High-Flow Throttle Body (coming soon...maybe lol)
Interior: Portable Sirius Stilletto 100 w/car kit, Garmin Nuvi 680 mounted below rear-view mirror, LCI-style I-drive knob, Dark Poplar Center Dashboard Trim.
Exterior: E60 forum clings, 5% rear tint, ACS roof spoiler (painted black for distinct look against limo tint), ACS trunk spoiler, ACS add-on front spoiler and rear apron (awaiting installation), "18 Black Staggered BeBeS Style OER (emergency replacement for cracked sport 124 rims), black kidney grill, white accessory lighting (including license and trunk lamps), Angel-eye upgrade, AIB xenon-matched fog lamps, AIB V3's on order, red rear reflectors
Thank you!
Thank you!
Well, thank you so much!
You've literally made my day! Hopefully the CCC test will be positive and I'll make the retrofit.
Do you know if I can use the 6.6" monitor to test the CCC, becuase I still don't have the 8.8", I'm waiting to find a CCC module first, but in order to fully test it I want to see how it works.
Thank you again!
Thank you again!
My Ride: 06 550i
Model Year: 06
Not to thread jack but I just received a M5 controller. The donor car had nav but mine doesn't, will I need coding to make it work?
Thank you again!
Thank you again!
Thank you again!
Thank you again!
As far as High and Lo Controller...I believe High just gives end of option feedback response. You can use it, it's not a problem. May not even need coding. My car was pre-wired for nav w/voice and I did not replace the iDrive controller but I may have had the High anyway because I get feedback.
yes you can use your 6.6 monitor, plugs right in,
Thank you!
Thank you!
My Vehicle is manufactured 07.2003. I have the Business Navi and the CCC is plug-n-play, only coding. I've tested a CCC module, but I guess it was dead, because nothing happend when I connected it. The screen was blank, there was a DVD inside it and I couldn't eject it.
I read that when you connect the CCC, without any coding you should get something on the screen, is that right?
Awest91
09-17-2022 11:05 PM
DavaiLave
08-02-2022 02:16 AM
