Dent on the hood
Old 04-24-2009, 09:41 PM
Gene's Avatar
Originally Posted by EBMCS03' post='857858
Because the hood is aluminum I don't think you'll be able to fix it with a dent removal kit.
Originally Posted by EBMCS03' post='858242' date='Apr 24 2009, 10:32 PM
Thats waht I said... but no one seems to listen.
that does not look like the same statement E
Old 04-25-2009, 01:34 AM
Bob525D's Avatar
I wouldnt use the dry ice method if its the same one i am thinking of where you use a hairdryer to heat the panel then rapidly cool it to pop it out, heating the metal can weaken the metal.
I had a dent in mine when i bought it, I tried using the glue stick approach but it didnt seem to do much. In my frustration \ last ditch effort i tried to push it out from under the bonnet (hood), i used my fist in a hammer action aiming for where the dent was. It actually worked, I cant see the dent anymore. I basically pushed the dent from underneath to observe the metal moving, i did this till i knew where to strike it took about 3 hits but it worked a treat.
In short go visit a PDR guy if you are not sure.
Bob525D's Avatar
Argh.... Double post, sorry.
ilovemye60
11-10-2015 07:48 PM
wooboodoo
10-25-2015 02:58 PM
alexbaldy
09-28-2015 12:28 PM
ucsbwsr
09-19-2015 10:58 AM
umichchris
09-10-2015 12:54 PM
Quick Reply: Dent on the hood
