Definitions
There are a lot of terms floating around here that make it hard for new folks, so I thought I'd start a "definitions" post. Please add on as you see fit...
LCI: ?
pre - LCI:
AE: Angel Eyes
TPM: tire pressure monitoring
DLR: Day light running lights
LCI: ?
pre - LCI:
AE: Angel Eyes
LCI = Life Cycle Impulse. It's when BMW makes changes to update the car during the same body style cycle. In the case of the e60, LCI cars started in 2008 and went through 2010. Pre-LCI were 2004 though 2007.
Let's see, what else...
DLR = Daytime Running Lights
AW = Alpine White, TS = Titanium Silver, etc.
FTM = Flat Tire Monitor
M54 = inline 6 used in 2004 and 2005
N52 = inline 6 used in 2006 and 2007
N54 = inline 6 used in LCI cars (see HPFP) High Pressure Fuel Pump :-))
PDC = Park Distance Control
CIP = Coding Individualization & Programming
HUD = Heads Up Display
ACC = Active Cruise Control
ED = European Delivery
There might be a PDF in the FAQs.
RTFM - Read the "fricken" manual... one of my favorites
My Ride: 2015 435xi GC
VTC = valvetronic
SVT = servotronic
RDC = tire pressure control
EDC = electronic damper control
EGS = (electronic) tranny control
OEM= original equipment manufacturer
RLS = rain light sensor
TCU = telematic control unit
ULF =universal charger and handsfree sys.
SGM/ZGM = safety and gateway module
and some stuff you may have seen on BMW badges..
d = diesel
ci = coupe (gasoline engine)
cd = coupe (diesel engine)
and if you need more, try Google!
DLR should be DRL for Daytime Running Lights
AS = Active Steering
ARS = Active Roll Stabilization
TPM = Tire Pressure Monitor, uses pressure sensors located in each wheel (successor to FTM, Flat Tire Monitor, uses ABS tire speed sensors)
ABS = Anti-lock Braking System
ucsbwsr
20
09-08-2015 08:30 AM
