Default nav view
Old Jan 2, 2006 | 10:39 AM
Geo's Avatar
Geo
My Ride: 530i
Is there anyway to display a map view in the large window immediately after hitting the accept button? I find it frustrating that I have to do a voice command or go through a number of iDrive sub-items to display the map on the left side. I can get it in the small window after hitting entertainment, but would like it to display in the larger window.
Old Jan 2, 2006 | 11:07 AM
DD694's Avatar
My Ride: 2006 550i Sport Package, Cold Weather Package, Premium Sound Package, Comfort Access, Xenon Headlights, Adaptive Headlight Control, Navigation System, Steptronic Transmission. Silver Gray Metallic with Gray Leather. Added Red rear reflectors. Swapped stock Style 124 wheels and Bridgestone run-flat tires for BMW Style 125 5-Double Spoke wheels, 8" x 19" front, 9.5" x 19" rear with Michelin Pilot Sport PS2 tires, 245/40YR-19 front and 275/30YR-19 rear.
So far I have not found any way to do this either.
Old Jan 2, 2006 | 11:21 AM
Brendan's Avatar
My Ride: 530iSE, Black Saphire with beige leather, auto, lux pack, comms pack, viz pack, power mirrors, 122 wheels
Try holding the iDrive control to the right for about 3 seconds, it should then switch to the last view you had on NAV. This also works for Comm, Entetainment and climate... just hold the control in the relevant direction wherever you are in other menus and it will return to the last screen.
So when I shut the car down it is in NAV with a perspective map. When I start up again I just hold the control to the right for 3 seconds and the map is back again.
Not automatic, but at least just one move
Old Jan 2, 2006 | 11:26 AM
DD694's Avatar
Thanks. Will give it a try.
Old Jan 2, 2006 | 12:02 PM
znod's Avatar
Right on.
Old Jan 2, 2006 | 12:05 PM
Brendan's Avatar
at long last I am able to return some help
Old Jan 2, 2006 | 02:15 PM
palmagora's Avatar
Many thanks !!
Old Jan 2, 2006 | 03:17 PM
Geo's Avatar
Geo
My Ride: 530i
For some reason, I get the new route prompt/menu selection and no map when I push the selector to the right.
Old Jan 2, 2006 | 04:28 PM
Freewilly's Avatar
My Ride: 2013 535i (White with Oyster Interior. Premium Package, Navigation, Technology Pacakge, Park Distance Control, and Rear View Camera)
This doesn't work for me....
When I hold iDrive control to the right for 3 seconds, it only switch to NAV mode, not to the map nor last screen. I have to move the iDrive control down 2 times to get to Map Facing North.
Similar things to Radio and Communication :thumbsdown:
Old Jan 2, 2006 | 04:33 PM
Brendan's Avatar
When you hold it to the right for 3 seconds it will revert to the way NAV was left last time, even if the car is shut down. The advantage is that if you go from NAV to the phone and back again you can do it without ever clicking, just by holding the iDrive in the right direction.
I guess if you are getting the NAV menu page then that was the page the nav was left in when last used. If it has the map selected when it is left, then when selected with the hold function it should go straight back to the map.
Oh well my best shot and the only short cut I have come across.
