Decreased radius for Remote Doorlock
#21
Its actually the module in the car thats about to go, i had the same problem and the dealer changed it for me and replaced both the keys works miles away now lol.
#22
Looks like I'll be ringing the garage this week and booking it in while it's still under warranty.
Poolie
#23
#24
My Ride: 07 525i
Originally Posted by qas1981' post='1012970' date='Sep 21 2009, 02:57 PM
Do you know which module it is? The dealership here is completely clueless.. They said it was the tint on my car causing the issue & its no faults in the system. Basically they cant diagnose the issue until the part fails completely b/c then it would throw and error code. This is my understanding.
#25
Originally Posted by ukamath' post='1013283' date='Sep 21 2009, 08:54 PM
Its called the diversity antenna and its on the rear window of the car on the passenger side on the top. Its about $150 and easy to install. This is the antenna for remote and for the FM/AM radio. I had my FM radio reception go out and this part was replaced, after that my remote distance was terrible. Its easy to replace if you are out of warranty. You might also check if its seated properly on the window. There are spring clips that attached to the "window antenna". The whole assy clips to the window.
I had a look in this area a couple of days ago, first I removed the cover thats over the high level rear brake light then carefully pulled the roof lining to partially reveal the antenna unit. I seen what you describe as the spring clips but thats as far as I went.
I didnt want to remove the clips and damage any connections between the antenna and the window.
I seem to recall that at the same time my remote started playing up my FM reception was poor (it still works ok but the reception in front of my house was poor).
It would really help me if you could let me know about the connection type so that I can be brave and remove the unit.
Thanks again,
Poolie
#26
My Ride: 07 525i
Originally Posted by Poolie520' post='1013679' date='Sep 22 2009, 07:54 AM
Do you know how the connection gets from the window to the antenna? Is it hard wired or pull off connectors?
Thanks again,
Poolie
Thanks again,
Poolie
There are wires that come from from the diversity antenna to a connector that is under the panel with the airbag sign.
So to remove the antenna:
-Pull off the trim piece under the upper brake light, there are no screws, just pull around the edges.
-Remove airbag sign, very easy to scratch the airbag badge as if you have use a screwdriver or knife, maybe plastic tool is better, I had to buy a new one ($3)
-Remove screw under airbag sign (its a torx I forget which size)
-pull of this panel, its just click fit
-you'll see a bunch of 7 small wires to a connector from diversity antenna. Remove this connector, there is also a ground wire screwed into the body in the same location, take torx screw out and remove ground wire.
Be careful when removing the antenna, don't push on the tabs to hard you might break them. This is the most difficult part as you have to pull down the trim and if you pull to much you will probably ruin the roof trim. Before changing the antenna I would re-seat the antenna, maybe just remove it, clean of the contacts and put back on.
There is a antenna on ebay for 65GBP (item 290188712029) however this is only for UK cars as frequency for remote is 434Mhz, USA is 315Mhz and 800Mhz (comfort access). This is printed on the back of your keyfob.
#27
Ive just disconnected the antenna from the window and it made no difference to the range of the remote.
So I guess this proves it. Im going to ring BMW tomorrow to make sure its covered under my UK BMW Approved used car warranty.
Thanks for your help.
Poolie
Poolie
#28
Im going to give this a shot. Where can I get the US version? from the dealer? 150 is a good price. I just paid 150 for a key that didnt work at all after they assured me it was just the key.. Very frustrating. This of course after they checked the system and verified it wasnt any faults in the system.
#30
Originally Posted by qas1981' post='1014057' date='Sep 22 2009, 02:57 PM
Can someone post a pictures of this as well?
Thanks!
Thanks!
Poolie
