When my new 545i sport arrives next week, I have opted to retain whatever run- flat tires BMW shipped the car with. Though I really dislike the firm ride of my current cars run-flat Dunlops, the dealer cost of switching is not worth doing it. They want a flat 25% charge to start, the difference in the cost of the tires between the run-flats and the Michelin PS2 non run-flats I wanted, the cost of mounting and balancing (at the rate per hour at BMW that adds up) and taking the responsibility that when they remove the run flats, if the bead is broken or the tire is damaged in anyway, that you are responsible for the cost of the tire (BMW advises they are very difficult to remove from wheel with out damaging). With a little bad luck, the whole deal can possibly add up to over $1,000. Don't think it is worth it. Maybe I will luck-out and get Bridgestone or Pirelli Run-flats which might be better riding. Car is about an April 1, 2005 build date, or there about, so who knows what brand of tires it will arrive with. Ship arrives in N.Y. port next Monday, so not long till delivery now. I guess I will just keep the tire pressure toward the low side of the chart on the run-flats, and if they wear a bit faster so-be-it, at least the ride will be bearable.
[snapback]118345[/snapback] |
I think the ride quality on the 545 sport is great with RF. Now, once they wear down, they may get noisy as some have said. If that is the case, I will have BMW replace them under warranty. If you really want non RF, you are probably best off removing them at a tire store and Ebaying them and buying new tires from tire rack.
You'll probably get less than 25k miles out of the tires, so stick with what you get and buy what you want later. I expect delivery in early June, but am hopeful for Bridgestones (they look good too). I had Bridgestones on my 2004 530i, my truck and Maxima. They wear and ride good.
Originally Posted by Kevin' date='Apr 22 2005, 02:20 AM
You'll probably get less than 25k miles out of the tires, so stick with what you get and buy what you want later.? I expect delivery in early June, but am hopeful for Bridgestones (they look good too).? I had Bridgestones on my 2004 530i, my truck and Maxima.? They wear and ride good.
[snapback]118387[/snapback] |
april first? really? heh...
