Dealer Story about OEM Batteries vs. Aftermarket
Old 05-19-2009, 06:04 PM
Howitzer's Avatar
So my 2004 530i was at the dealer yesterday and today to seal up the vent that is located in the trunk in the battery compartment because...... it was accumulating water. Thats right! WATER, about 3" of it... near the heart of ALL the electrical components in the car! How freaky is that? Well apparently this was a known issue and BMW released a bulletin on it or whatever. My dealer was nice enough to fix the problem under my CPO, (but its normally only covered under factory).
To get to the point... the dealer said they were concerned they noticed an Interstate battery there and not an OEM one. I said: "why? Its either I replace it via you for $330 or via myself for $80." They are exact specs as OEM. Well the "service advisor" stated that the OEM battery has a vent tube but the aftermarket does NOT. Therefore, the problem with that is acid cannot drain when the battery becomes hot or whatever and it can cause corrosion at the top of the connectors, etc.
You guys confirm this? I mean, am I going to burn a damn hole in my trunk from battery acid seeping all over the place, end of the world scenario like the dealer made it sound?
Old 05-19-2009, 06:12 PM
Jrowe's Avatar
My Ride: 2005 545i Sport Package Limo Tinted, Heads up display, Fully Loaded Minus Cold Weather Package and Rear window Sunshades.
Haha no. They will come up with all kinds of crap to make you see how paying an extra $250 is necessary. I never heard about this happening in all other cars that aren't BMW's? So why would it happen now? I bought a battery that has more cranking amps and a better warranty then the ones BMW have for only $130 and wouldn't hesitate to tell anyone else to do the same.
Old 05-19-2009, 06:20 PM
Howitzer's Avatar
whew!
P.S. - They were very annoyed that I kept referring to BMW bulletins and what I read on a forum about this or that and I just happened to be correct about EVERYTHING - thanks to e60.net. =)
Old 05-19-2009, 06:23 PM
lorinzo's Avatar
Come on.... battery manufacturers know where their batteries can and cannot be used. I find it hard to believe that Interstate doesn't know that it can't (according to your BMW service rep) be used!
Last time I looked, a car battery is pretty much a car battery, regardless of brand.
Old 05-19-2009, 06:54 PM
CWS530's Avatar
Well, you do need a vent tube to expell battery gases, but it's integral to the car, not the battery.
Old 05-19-2009, 06:55 PM
wlkonacloud's Avatar
My Ride: 2008 550i Alpine white
Originally Posted by Howitzer' post='883802' date='May 19 2009, 10:20 PM
whew!
ha ha, yea you tell them
Old 05-19-2009, 06:58 PM
heavy_g's Avatar
My Ride: '05 545i
actually there's is a vent tube in the OEM battery. it is advised to get one that has a vent tube as well.
for example. i bought a Werker battery (BMW OEM battery maker) which has the vent tube.
Old 05-19-2009, 07:01 PM
heavy_g's Avatar
My Ride: '05 545i
CWS530's Avatar
for example. i bought a Werks battery (BMW OEM battery maker) which has the vent tube.
Then what was that diagram Luigi put up? Looked like it was built into the car? Guess I should have looked after they replaced mine.
Old 05-19-2009, 07:04 PM
heavy_g's Avatar
My Ride: '05 545i
here's a close up of the tube:
Quick Reply: Dealer Story about OEM Batteries vs. Aftermarket
