Dealer Programmed Options + Inspection
What options can only be programmed by the dealer? My E46 M3, had the basics (daytime running lights, doors lock after 10 mph, etc.) But with iDrive I don't know what has to be programmed by the dealer.
Also, any hints on inspecting the car before taking delivery? That assumes I will be acting logically when I go to get it.
Thanks.
Dan
Thanks.
Dan
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
DanM3,
You can program everything with the iDrive except for the DRLs.
As for delivery, make sure there are no dents anywhere. Look at the car from many, many angles. Also, make sure all the Cosmoline is properly removed. Look carefully around the sideskirts. If the stuff is still there kindly ask your CA if they can have someone remove it. Cosmoline is the protective coating applied to all cars while in transatlantic transit.
My Ride: E61 520d SE, Black Dakota, Bluetooth
Originally Posted by jiio' post='308038' date='Jul 7 2006, 09:49 PM
DanM3,
Originally Posted by sguilliard' post='310749' date='Jul 14 2006, 12:36 PM
I can switch DRL on or off in iDrive...
Yes, DanM3 has not yet updated his profile but I do know he is from the Los Angeles area.
DanM3, that's a hint to update your profile.
DavaiLave
08-02-2022 02:16 AM
