Day running lights
Administrator
My Ride: 530D Touring M Sport manual
Hi, didn't know there were fuses in the boot, can you say if these day running lights have a dedicated fuse? I have looked at the fuses behind the glove box on the passenger side but there is no diagram or info to indicate what fuse is what. paneuro
My Ride: Sold: 545i, sport package, cold weather, 6MT
Engine: N62
Regarding the DRLs, I'm sure they are part of a lighting fuse (I have an 04 and don't have them so I can't answer this question for you).
Exterior lights, headlights, marker lights, tail lights, etc are controlled by a light module (LM). The LM is a computer that switches lights on and off as require to complete requested functions. The module has the ability to detect irregularities within a light circuite and power off the affected light/lights. If the halo lights are not burned out, then you will need to use test equipment to determine what is going on.
Here's an idea of the form of testing required to determine what your problem may be.
All BMWs The Official Guide To Resetting A Short Circuit Fault In A FRM Module - Bimmerfest - BMW Forums
