Damp in adaptive headlights
Old 02-01-2011, 02:00 PM
Dandle's Avatar
My Ride: 07 E61 530d M-Sport.
Originally Posted by DavidF
It works for mine, especially if I use the "flash to pass" halogens to get things heated up a bit faster. The headlights are vented to atmosphere so the moisture can escape with the expanding heated air inside the light. No way to open them up for cleaning.
No flash to pass halogen on the adaptive headlights and the xenons are only 35w and inside a projector lens. They need replacing if they are really bad, at the end of the day Hella didn't design the lights to mist up so its not right.
Old 02-02-2011, 08:29 AM
DavidF's Avatar
My Ride: 545i sport
Well, my '04 has adaptive lights, bixenons, angel eyes and flash to pass halogens. The projectors are not sealed and open to the rest of the headlight assembly air. 35W will warm the air and expel moisture, just takes longer than hight wattage. If you want the moisture to get out faster, disconnect the electrical plug as this opens the assembly to the outside atmosphere. Head the headlight (carefully) with a heat gun or something.
Old 02-02-2011, 01:29 PM
Dandle's Avatar
Your car has the older headlights. andrewsweetnams is an LCI and has cornering lights instead of a halogen lamp, flash to pass stikes the xenons up. Turning the lights on will not dispel the moisture and if the day is damp it will just cause more due to condensation. The only fix is to get the lights replaced like a couple of us have. They are faulty if the mist up that much.
Vman33
03-14-2022 04:43 AM
umnitza
11-25-2015 11:10 AM
EuropeanArtz
09-29-2015 04:26 PM
Kewill0360
09-28-2015 07:32 AM
Bogdan7
09-23-2015 11:40 AM
Quick Reply: Damp in adaptive headlights
