D1S bulb
Old Aug 25, 2012 | 09:59 AM
pasha999's Avatar
My Ride: bmw 530d e60 in silver with M5 spider wheels,stage 3 re-map,upgraded to CCC,LCI lights,etc etc
Hi folks, anyone know how connect D1S bulb with aftermarket HID ballast? D1S has 3 wires in the ignition coil,i believe 2 of them are poss and neg,whats about the 3rd one? any help?
Old Aug 26, 2012 | 11:26 PM
MORI3L's Avatar
My Ride: 08 528i TiAg Premium/Cold Weather Pkg, 20% Tint, Technic Harness, JL Audio 12W7, JL HD 750/1 and LOTS of lighting mods!!!!!
Why don't you just retrofit a D2S kit if you're going to go aftermarket? It'll be much brighter and whiter...
Old Aug 27, 2012 | 12:01 PM
paulie's Avatar
My Ride: E61 525i 2005, F11 528i 2012
Model Year: 2012
Try this site...It has a schematic of the D1S bulb connections. Hope it helps.
http://www.xevision.com/hid_specifications.html
As far as I know, the D1S is a further developed D2S lamp. There is basically no difference in brightness or colour. The D1S has the same lamp as D2S but the ballast in build-in to the lamp (the square box) instead of being separated as in D2S.
Old Aug 27, 2012 | 12:44 PM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
http://www.xevision....ifications.html
Correcto.
Old Aug 27, 2012 | 01:20 PM
MORI3L's Avatar
The brightness or color would vary if you were comparing an aftermarket 50W D2S kit to stock D1S bulbs with aftermarket ballasts. As far as I know there is no 50W D1S solution which means that the higher you go on the kelvin scale with that D1S setup the more brightness you lose. When comparing the actual bulb to each other there is little difference other then the base (igniter) as you stated.
derooster
Sep 22, 2016 07:30 AM
jluzbet
Nov 7, 2015 01:25 PM
umnitza
Nov 3, 2015 02:58 PM
umnitza
Sep 2, 2015 11:28 AM
Bounce
Aug 31, 2015 10:04 AM
