cross winds and active steering
Was pretty windy yesterday and today in Boston, so driving to work on i95 north i noticed smth very strange. When the wind moves the car the steering seems to compensate for it. But it's not acurate and feels very weird.
It felt like my wheels were loose. I stopped and checked the bolts with the toruqe wrench - perfect 88. so ichecked preassures 35 on warm tires - OK.
I kept on going and experimented with speeds. It seemed to be less noticable at higher speeds (more downforce, less sensitive steering), but as soon as I drop to 55-60mph, it's all over the place
I turned the DSC and DTC off completely - it seemed to cure the situation a bit but still smth was left.
Drove M3 today with simialr winds - no problem, occasially you get blown with high gusts but with normal steering it's easy to compensate.
Has anybody else experienced this? Does Active steering really interfere this much?
car is 05 545 so the software is the latest 15.x
I kind of got used to active steering in normal conditions but it steel suprises me in snow, ice, water and now Winds... bummer
My Ride: 2008 535i
[snapback]97255[/snapback]
I experienced this, until BMWNA replaced the Dunlop RFT tires with Bridgestone RFT tires. Problem solved. Are you running with the Dunlop RFT tires?
I experience the same thing. And, I do believe that the tire setup makes a difference. Mine's more pronounced now with my new Eagle GSD3s than with the Dunlop RFs. I would "think" that the amount of correction is defined in the software and how the car reacts will vary based on roads, wind changes, tires, suspension, etc. So, some under and overcorrection would be normal.
My Ride: 2008 550, Carbon Black Metallic, Natural Brown Dakota Leather, Sport Package, Sport Automatic Transmission, Cold Weather Package, Power Rear and Manual Side Sun Shades, etc.
Retired - 2004 545 SMG, Black Sapphire Metallic, Auburn Dakota Leather, Cold Weather and Sports Packages, Power Rear and Manual Side Sun Shades
I also thik it is the Dunlop RF's. i experienced similar things in wind and at high (90 mph+) speeds. i have winter wheels and tires on now (Michelin) and have not experienced the feeling at all.
JohnW - do you have wheel 124 with Eagle GSD3s? I was thinking about replacing my RFT with Eagle GSD3s after I put some more miles into Dunlop RFT. Does Eagle GSD3s make the car wonder all over the road?
Originally Posted by John W' date='Mar 4 2005, 02:43 PM
I experience the same thing.? And, I do believe that the tire setup makes a difference.? Mine's more pronounced now with my new Eagle GSD3s than with the Dunlop RFs.? I would "think" that the amount of correction is defined in the software and how the car reacts will vary based on roads, wind changes, tires, suspension, etc.? So, some under and overcorrection would be normal.
[snapback]97272[/snapback]
My Ride: 535D Sport Auto
I'm on the stock staggered 124 setup with the GSD3s. It doesn't wander, but it is twitchier. The tires are a whole lot quieter and more comfortable, but the car twitches more with AS corrections and when crossing large pavement flaws. But, it doesn't really tramline and is very stable on good surfaces.
I may try something else next time - I'm not as much in love with these as I was with them on the E39 540.
Originally Posted by katmai' date='Mar 4 2005, 05:05 PM
JohnW - do you have wheel 124 with Eagle GSD3s?? I was thinking about replacing my RFT with Eagle GSD3s after I put some more miles into Dunlop RFT.? Does Eagle GSD3s make the car wonder all over the road?
[quote name='John W' date='Mar 4 2005, 02:43 PM']I experience the same thing.? And, I do believe that the tire setup makes a difference.? Mine's more pronounced now with my new Eagle GSD3s than with the Dunlop RFs.? I would "think" that the amount of correction is defined in the software and how the car reacts will vary based on roads, wind changes, tires, suspension, etc.? So, some under and overcorrection would be normal.
[snapback]97337[/snapback]
[/quote]
alienintelligence
09-07-2015 12:09 AM
Johnnywadd
09-03-2015 01:23 PM
