Crank, No start. (E60 550i)
My Ride: 2008 BMW 550i M Sport
![Angry](https://5series.net/forums/images/icons/icon8.gif)
Hey everyone.
In the previous months (December-january) my 550 started throwing TPS codes. after replacing the entire throttle harness, the throttle body, AND the gas pedal, i threw in the towel and got a civic.
Since then the 550 has been sitting in the parking lot, and as I am moving soon i need to get it out....
So today i charged up the battery and went to start it. Cranked very healthy! Although it just kept cranking. and cranking. and cranking.
I tested the fuel rail and it definitely has gas in it. and it's definitely pressurized. I sprayed in some starting fluid into the intake and voila! The engine caught for maybe half a second (and it sounded ROUGH) and then died and went back to cranking. I pulled several codes earlier however when i went to read them again they all vanished! I even replaced the Fuel pump relay to no avail (rip 30 dollars)
Should i test the coils and plugs?
Should i also test the fuel pump itself?
Is there any other part of the car that would cause a crank, no start?
I just want to move it. Lmao, i think this car is alive and hates me.
Edit: The model year is 2008.
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
You need to post the codes you had on there. Right now you have a crank but no start. That could point to the fuel pump. You got it to start so it would not be spark or CPS. Is the pump priming in the 2 position? There is no way to troubleshoot without codes unless you do it blindly. I would say start at the pump itself because you can not get it to start. Maybe the fuse.
the codes I pulled before having them all disappear were:
p0024
p0120
p0221
p1631
p1647
p00c1
c1516
U0155
How would I go about testing the fuel pump? I tested fuse F50 located in the trunk which was fine, and I just replaced the relay.
Model Year: 05 530i
Engine: 3.0 M54
You my friend might have a blown head gasket. Has this car been running while overheated? Please tell the whole story of why it was parked.
Would a a blown head gasket prevent the fuel pump from priming when the key is in pos 2?
I cant get solid codes out of the car even with the battery charged. They seem to change every time I connect my scanner, or they disappear completely.
Should I just get rid of the car? Lol
My Ride: 07 550i Sports Package
This code p1631 has to do with the theft deterrent system. Research that, that would cause the car not to start, You are getting a spark and there is gas in the system. I would try realigning the CAS and DME. Also, those are a lot of varying codes which is usually caused by power surges or battery issues but are not actual.Have you fully charged the battery or replaced it?
