Crank no start
My Ride: 05 530i m tech 6 speed
Crank no start
Long story short, I moved my car around the driveway (like 20 feet) and then let it sit for 3 days as I had family over for the holidays. I went to go start my car and it cranks but will not start. I have checked the fuse and it’s good. I have tested the relay and it’s also good. I am not getting a power reading on the white and blue wire on the pump connection though. If I put my power probe where the relay goes, I do not get a reading where the bottom prong of the relay goes. I tried changing the crankshaft position sensor and it still won’t start. What do I do?
Well the battery was good (I think) because it was cranking strong. After messing with it for so long though I did kill the battery. I will fully charge the battery tomorrow and try another key although my other key has only worked for about 20% of the time that I’ve owned the car. The car goes thru phases where it recognizes the key sometimes but most of the time it doesn’t
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Usually when I have that issue it's the battery. Longer cranks mean the battery is not strong enough. How old is the battery? My car sits for weeks at a time and when I don't put it on a tender it takes a while to crank or I have to charge it to get it to crank.
My Ride: 2009 535xi Touring 6MT, 2001 325i 5MT
Engine: N54, M54
I wonder if it’s flooded? Twice on my E46, if I start it on s cold day and move it around the driveway it won’t restart later. Turns out since it’s cold and sprays more fuel in but the block isn’t warm enough to vaporize it, the fuel sits. For that car I crank it with the throttle fully depressed and that puts it in flood mode where it shuts off the fuel injectors and allows you to just pump air through the motor and get that fuel out. Sorry if it doesn’t help you, it’s just helped me twice with that M54.
So I tested the battery and it was completely dead and wasn’t holding any charge when I put my charger on it so I went to the dealership and bought a new one. Threw it in hoping that would be it and unfortunately it still won’t start. It gets SO CLOSE to starting but it just doesn’t. I don’t know what to do. New to this so I don’t know if the video will upload but I took one of how it’s acting
How load is the noise the pump makes on this thing? Because I have the rear seat out and I still don’t hear anything when I put the key in and like I said, the white and blue wire isn’t getting power but the fuse and relay are tested and good
