Crank Case leaks - estimate to fix?
Old 11-21-2014, 07:09 AM
galaxy's Avatar
My Ride: e60
Model Year: 2005
Default Crank Case leaks - estimate to fix?
The shop called me about the leaks and anyone has a done job recently? and any price info available?
appreciate your response.
Thanks
~H
Old 11-21-2014, 08:05 AM
txag_530i's Avatar
What is leaking? Front shaft seal? Rear shaft seal? Crankshaft position sensor? Oil pan gasket?
Old 11-21-2014, 09:26 AM
galaxy's Avatar
My Ride: e60
Model Year: 2005
Oil pan gasket
Old 11-21-2014, 10:10 AM
twh
twh's Avatar
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Originally Posted by galaxy
Oil pan gasket
What model car?
How long have you owned it?
Have you ever had to add oil? If so, how much and how often?
Do you notice oil on the garage floor? If so, how much and how often?
Have you dropped the plastic under shield and noticed oil in it? If so, how much and how often?
My two cents...If there isn't much oil, just monitor it. All cars have oil filming around gasket surfaces after some age.
If there is no need to add oil between oil changes, I would just monitor it and if it gets worse, I'd deal with it. Of course, if it is a simple job, just do it. Oil pan gasket is not a simple job.
Old 11-21-2014, 05:05 PM
Mr.Logical's Avatar
My Ride: 2007 525xi
I have a 2007 525xi with front main seal leaking. I got an estimate from $2,400 from an independent to $617.00 from the Dealer.
I am doing it my self.
I got a seal removal tool $110.00
Manual pdf format $10.00
Seal $24.00
Sealant with a primer, Using permatex instead of Loctite $25.00
So far It has not been very difficult, other than getting proper torx socket to remove Vibration damper.
Old 11-22-2014, 03:15 PM
pcy
pcy's Avatar
Mr.Logical, let us know how the front main seal replacement went...
Old 11-24-2014, 03:33 AM
Mr.Logical's Avatar
My Ride: 2007 525xi
The seal replacement went very well....
Initially I was very nervous... After reading the manual and getting a few bits of info hear and there I made it happen.
Check out this link below... Nick at Pelican parts gave me some info to start, that's why I posted the follow-up there.
I could rent you the seal puller if you need it... Just fyi or sell it... I hope to never need it...
http://forums.pelicanparts.com/showthread.php?t=839527
Old 11-24-2014, 06:30 AM
twh
twh's Avatar
Engine: N52
Very nice.
Old 11-24-2014, 10:46 AM
pcy
pcy's Avatar
Mr.Logical, I am currently out of town; will contact you after Thanksgiving about the tool rental and the sealant.
Old 11-24-2014, 11:19 AM
Mr.Logical's Avatar
My Ride: 2007 525xi
Ok, you can contact me at jeff.stromatt@yahoo.com
Did you check out the link I posted that takes you to pelican parts forum? I posted several photos.
Quick Reply: Crank Case leaks - estimate to fix?
