Couple of Runs with the G-Meter * Updated *
#281
Originally Posted by swajames' post='336137' date='Sep 19 2006, 06:52 AM
By the same logic, stick a g-meter in 550 and with similar amounts of practice it's reasonable to assume that in time you will beat the magazine numbers as the 545 owners seem to have done.
Thats what I'm thinking... its all relative...
#282
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Anyway, I finally got around to reading the G-Meter manual after all this time. I found out that we haven't been using the rollout feature.
![Doh](https://5series.net/forums/images/smilies/imported/doh.gif)
Znod and grogan545i, do the both of you use this feature?
#283
My Ride: 2008 550I,manufactured 2-27-08,delivered 4-2-08.Platinum bronze,natural brown interior,light poplar trim,cold weather package,heated rear seats,HD radio
Originally Posted by EBMCS03' post='335835' date='Sep 18 2006, 03:29 PM
The way I launch it is Left foot on brake right foot on gas... I let off the brake fairly fast and as let off I feed gas... Kinda like driving a manual and letting out the clutch... Seems to be working for the IS so its ok for me.
If Brian Will let me I'll would like to try to do one or two launchs on a 550 and see how it goes...
EBMCS03 IS 350 Auto Curb Weight 3,527 306 hp 277TQ
brian1225's 550i Step Unladen Weight 3814 lbs 360 hp 360 TQ
#284
Originally Posted by EBMCS03' post='336024' date='Sep 19 2006, 12:31 AM
I'm betting you can. Less gas. No spare. cold weather... under 5 for sure. I bet my IS can get under 5 too... I had too much gas in the car this time and still have the spare and all carpet in the car including the tunk carpet matt... thats heavy. ![Tongue](https://5series.net/forums/images/smilies/imported/tongue.gif)
#285
Originally Posted by vegastrashed' post='336217' date='Sep 19 2006, 12:58 PM
I'm not your relative.
#286
Originally Posted by grogan545' post='336227' date='Sep 19 2006, 10:11 AM
If you did not set this feature in your GT2,the default value is 12".Both Zman and myself use the 12" rollout setting.This most closely imitates drag strip conditions(the stage beams are 12" apart).In order to use something other than 12" you must go into the program mode and change it.I tried using 0 rollout when I first started testing.All times were approx. .3 secs longer.
So it really doesnt make "that much" of a difference... meaning our 545s and 550s here should be getting MUCH better times than 5.7 <_<
#287
I guess the next question would be pitch settings. I remember Znod mentioning we should've made changes. Is the pitch the same for the 545/550? I'm sure it's different for the IS350. I'm doing a search right now...
#288
#289
Originally Posted by vegastrashed' post='336235' date='Sep 19 2006, 01:26 PM
Ok, so I don't have to modify the rollout setting. Leave it at default of 12". Man, I thought that it was 0 and by adjusting it to 12" my times would've been better.
#290
Originally Posted by Znod' post='335931' date='Sep 18 2006, 08:22 PM
Here you go g-manster. Got to it today after all--between x and y.
Calculate Density Altitude:
Your results:
Air Temp 57 (?F)
Altimeter Setting 29.94 (in)
Dew Point 57 (?F)
Altitude 400 (Feet)
Density Altitude 553.1 (feet)
Correct 1/4 mi. Timeslip to Sea Level:
Your results:
Uncorrected ET 13.56 (sec)
Uncorrected MPH 104.2 (mph)
Corrected ET 13.481
Corrected MPH 104.82
Correct 1/4 mi. Timeslip to New Density Altitude:
Your results:
E.T. 13.481 (sec)
Trap Speed 104.82 (mph)
Measured DA 553.1 (feet)
Corrected to 500(feet) DA
Corrected ET 13.474 (sec)
Corrected Trap Speed 104.879 (mph)
Corrected 0 -60 5.064 (sec)--My excellent estimate
Good one g-man. The weather helped you a tad. I looked back; it is one of your 5 best on an adjusted basis. So, give me a few days and I will substitute it in and change your average here. I still plan to get a few more in before the good old hot weather is gone.![Big Grin](https://5series.net/forums/images/smilies/imported/biggrin.gif)
Your results:
Air Temp 57 (?F)
Dew Point 57 (?F)
Altitude 400 (Feet)
Your results:
Corrected ET 13.481
Your results:
E.T. 13.481 (sec)
