Couple of Runs with the G-Meter * Updated *
Originally Posted by grogan545' post='317060' date='Jul 30 2006, 06:14 PM
Great to see others testing their cars.Pretty impressive times for the IS350.I reviewed some of my test data and noted that when I had times similar to the 350 in the 1/8(8.75,81.5) my 1/4 times were in the 13.40s at over 104 mph.It appears the IS350 falls off some at the upper end.When I tested at temps below 65F I had many runs 0-60 in under 5.00 secs,and 1/4 times in the 13.30s and 13.40s.If this was the first time testing with the G timer you guys did good.With some experimenting with different starting methods I think you all would see improvement.I found for my 545 step the best method is DTC/DTS off,brake torque to about 1000 rpm,release brake and slowly go to full throttle.This method gives me the best 60' times and no wheelspin.
I really have to work on this wheelspin stuff
I suspect this shows mainly that the SMG isn't as quick as the step in terms of straight line acceleration. Znod etc have hit sub 5 in a 545 and I suspect a step 550 would be a shade quicker still. But that's a phenomenal time in the IS350, EBMCS03
I want to run in cooler temperature. We knew the heat would have affected the times but since everyone was running under the same heat we got a good comparison on what each car can do.
I'm sure I can shave off a little time if I practice lauching. Impressive none the less 5.00 flat in 80 degrees even if the G-timer is off its still impressive!
Hollywood! Lets do a run!!
How about Iceman316's 0-60? x.9x s ? 4.9x or 5.9x ?
My Ride: Look At My Signature. -Other Rides and Previous Rides: 04 BMW X3 | 03 BMW 330i (Sold) | 05 BMW M3 (Gone)-
05 Infiniti G35 sedan, Premium Package, Bose Sound, HID, Sports Package, Hardwired Escort Passport x50 Blue Installed, New Transmission Installed, Navigation, Keyless Entry+Start
Other Current Ride.
Hey already posted???? hahahaha good run today, too bad g35 sucked! slow piece of crap at 6.63 going to trash it, or could it be my tranny problem? who knows why i went so slow. better luck next time, but i think im going to bring my 5 series and watch you guys run!
Other Current Ride.
are u sure i did 5.63?
well i dunno any more i dont think i did well i need g meter again i guess!
Are you sure you didnt? It was X.6x I dont remember what it was 5 or 6... was it 6???? maybe someone else with a better memory can chime in.
My Ride: 2007 550i White/Black, SMG, Sports Pkg, Comfort Access, Nav, HUD, Satellite Radio, Anthracite Maple Trim
2006 X5 3.0, Black/Black, Sports Pkg, Premium Pkg, Xenon Adaptive Headlight, NAV, Rear Climate Pkg, Anthracite Trim
