Coolant Low Warning
Hi all,
I have had my coolant low indicator go off 4 times since August and Everytime I bring it to the dealer, they say this is normal and because it is an 8 cylinder it runs hot. That was the explanation they are giving as to why i keep emtying my overflow tank. I would like to know if any one else here has experienced this issue. Oh...By the way, the car is a 2005 545i with 50,000 miles. It is under the CPO warranty as well.
Thanks
Thanks
My Ride: 2007 X3 LCI
Hi, I've had my car for 3 years and it's happened once. I filled up and that was it. Not sure it's supposed to do that four times since August? Welcome to the forums by the way!
My Ride: '04 545i, sport pkg, premium sound, sprint booster,
Originally Posted by as300z' post='1062358' date='Nov 25 2009, 09:04 AM
Hi all,
Thanks
Thanks
Thanks for the replies so far! I'm thinking this is much more than they are disclosing. The good part is the car just started the CPO warranty. if any one else has info on what this may be, please post it for me. This forum ROCKS. Everyone on here is quick to respond and are full of info.
Thanks Again.
Thanks Again.
My Ride: 2009 535xi, short shifter, no CDV
Could be (valley pan gasket) as sotic1 found in his car.
I have the same happened in e39 540i. When it starts, you got low coolant warning every 2+ months.... the length of time keep reduce until around 2 weeks.... Dealer talking bull shit that it is normal and they did pressurized coolant checking.... It still under under warranty by that time and I guess it needs to be "the machine tell them lost pressure" before they can do the service.
When car hit 80K miles.... I did a coolant system revamp ... I did open the top of V-block.... and found that leak in the Valley Pan gasket. Replace that as well..... and I never see Coolant warning until I sold the car at 170K miles.
BTW, when there is minor leak in valley pan gasket, since it is so hot there. The coolant just vaporized, it will take long time until you will see some coolant drip from back of engine area.... ( Mine drip from clutch housing which causing some funny clutch friction feeling. )
I found in e39 engine, if you open the top plastic cover, and use a flashlight. You can see some leak evidence through inlets and fuel injection rail. I am not sure you cans see it in e60 V8 or not.
You know, when I got the car it did this too. I topped it off at the resevoir and about 3 months later got the same warning. So i topped it off again. That was about a month ago. I just topped it off with distilled water since it was just a small amount. I'm wondering if I have a leak as well. I changed the spark plugs at 80K and didn't notice anything leaking at all. I was about to do a cooling system drain/fill soon anyway. I figured it was evaporating the water portion of the 50/50 antifreeze mix. Since it runs hot in Florida I figured it wasn't really an issue. Where is this valley pan at?
I had the same problem took my car to an independent shop and they fixed it. There was leak around the sensor and the shop replaced the o-ring around the sensor and have no leak. If you have a good independent mechanic they will put it on the lift remove the under cover and show you the leak. It took 10 mins to fix.
