coolant level stick broken!
Old 05-21-2012 | 11:06 AM
Excession's Avatar
My Ride: 04 BMW 545iA ZSP, ZCW, HUD, Silvergrau
Any aftermarket alternatives?
Old 05-21-2012 | 11:20 AM
Wolrab's Avatar
My Ride: 545i 2004, SMG, Sport, Nav, Logic-7, Bluetooth phone retrofit
If the stick is in such bad shape, it's time to replace the tank.
The level sensor is a reed switch that's operated by a magnet, presumably attached to the bottom of the float. So long as the float still floats, the level sensor should still work.
Old 05-22-2012 | 08:09 AM
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
The same thing happened to my coolant level indicator stick; it just broke into pieces. I had to buy a new coolant expansion tank, BMW part # 17137542986. The install was easy with the hose quick disconnect. Good luck .
Old 05-22-2012 | 10:46 AM
Wolrab's Avatar
Incidentally, when the float bumps up to the top of its travel, the tank is full. So the float is usable as a level gauge until you have a chance to change out the tank.
Old 05-24-2012 | 02:43 PM
infin8's Avatar
My Ride: BMW 550i M Sport
Model Year: 2010
Engine: 4.8L V8
My 2007 530i kept giving me an error mssg = low coolant level. I added coolant three times over 2 months before I took it in for repair under warranty. I was sure it was the expansion tank since this is such a problem for BMW's, but it turns out it was the radiator that was leaking. They replaced the radiator under warranty. The moral is if your stick is falling apart you probably are due for a new expansion tank, but if you're getting a low coolant level error you need to identify the leak before replacing the expansion tank. You might need that extra cash for a new radiator which I'm sure isn't cheap! The expansion tank could still be pretty well intact and can wait. It's already over 100 degrees everyday in AZ, and the last place I want to be is on the side of the freeway overheating with a brand new tank and a busted radiator! Just an fyi...
bestofthebest
03-28-2016 02:47 PM
Henry Peters
09-25-2015 10:15 AM
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
ST JAMES
09-14-2015 03:29 PM
AJH
08-30-2015 11:38 AM
Quick Reply: coolant level stick broken!
