coolant
Old Apr 5, 2010 | 03:14 PM
changer44266's Avatar
So i got in my car today and and it said super low coolant, figured id go to autozone pick up some prestone is what i got. After putting it in, i hear its not good to go with that, and you should use bmw coolant. Is this true and should i be worried about anything. Im not use to having this high end of a car, autozone is what i usually go with.
Old Apr 5, 2010 | 03:48 PM
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
You should have just added distilled water. The problem is with incompatible formulation with the coolant already in your engine.
If it's not a lot, you might be fine.
Old Apr 5, 2010 | 07:59 PM
John@Motorcepts's Avatar
Banned
My Ride: A Car
flush ur coolant ASAP!!!!! PLEEEEASE
Old Apr 6, 2010 | 02:45 PM
it was only about 1 1/2 qt. Should i worry about it and flush it or will it be ok.
Old Apr 7, 2010 | 01:50 AM
krieshan's Avatar
Hello, a 04 bmw probably uses NON- long life coolant. So if you used coolant stating 5 years lifetime, you should have changed it yesterday.
Mixing coolants, even the right coolant, is not recommended. And in the long term will result in unnecessary repair cost , like leakage, coolant pump and worse.
Don?t know when coolant had a change? Change now ! and every 2 to 3 years .
bestofthebest
Mar 28, 2016 02:47 PM
Henry Peters
Sep 25, 2015 10:15 AM
ST JAMES
Sep 14, 2015 03:29 PM
InsipidMonkey
Sep 13, 2015 05:11 PM
