control arm replacement help
Old 04-04-2012, 09:18 AM
  #21
turboawd's Avatar
My Ride: 2006 BMW 550i
Originally Posted by toyota2bmw
There should not be any fluid coming out of those two tubes. They are vent tubes. They join up and go into the subframe top-off with a plug. The fluids are carried by the two very mean and sturdy looking high-pressure hoses with metal fittings at both ends.
exactly.
check the two main hydraulic hoses. i have to snug up one of mine every so often as it works slightly loose for some reason.
Old 04-04-2012, 10:51 AM
  #22
best1's Avatar
My Ride: 2008 550i M-Sport
so should the yellow line be loose? mine moves in and out about 2 mm
Old 04-04-2012, 10:58 AM
  #23
healthservices's Avatar
Just a vent tube, I would not worry too much about it.
Old 04-04-2012, 01:50 PM
  #24
infin8's Avatar
My Ride: BMW 550i M Sport
Model Year: 2010
Engine: 4.8L V8
Sorry for the noob question, but how do you know you need new control arms? How do old ones that need to be replaced affect the car? Just trying to pinpoint an issue I'm having with my car's steering.
Old 04-04-2012, 02:44 PM
  #25
toyota2bmw's Avatar
it's the rubber bushing end that goes bad and starts leaking even. As they age, they crack/split/tear and don't provide adequate support for when the car is bouncing around and turning. It could also cause vibration in steering, front-end mis-alignment, etc. This is a great preventive maintenance project to do with a buddy over a 12-pack. That's what I did and by buddy did his just a few weeks after and we both felt a VAST improvement in ride quality and steering feel.
Old 04-21-2012, 06:06 AM
  #26
best1's Avatar
i finally got these parts replaced. The shop said they used an air chisel to break the knuckle loose. My right front bushing was torn pretty bad. The change in ride was not noticed but braking and turn in response are much better now.
Old 04-22-2012, 01:21 PM
  #27
AchtungE60's Avatar
My Ride: E60 530i
You didn't notice a change in ride quality at 50-60 mph? They couldn't have been that bad then lol.
Old 04-23-2012, 04:35 AM
  #28
best1's Avatar
They were bad. I will download a picture. It is cracked all the way through and i can push the center hub all the way over with my thumb. ride is the same if anything i have more steering feel.
Old 04-24-2012, 06:21 AM
  #29
best1's Avatar
Pictures of the right bushing.
Attached Thumbnails control arm replacement help-imag1419.jpg   control arm replacement help-imag1420.jpg
Old 04-24-2012, 06:25 AM
  #30
525iEnjoy's Avatar
Yep thats what how they were on mine
Quick Reply: control arm replacement help
