Connecting a laptop to the car
Hi,
I've seen mentioned on here people who are running some software on laptops which are connected to the car and allows them to see all the car's parameters and fault codes. I'm quite curious in keeping an eye on water temperature as I'm not sure the car is getting up to temperature. Is there an idiots guide to getting this software and how to use it?
I realise there is some hack that can be done which shows some diagnostics on the dashboard screen, but I think the laptop would be more useful for me.
Thanks.
Thanks.
I believe you are reffing to scan tools such as:
http://www.bavariantechnic.com/default.aspx
^more info about it there....it's actually very user...even a caveman can use it
http://www.bavariant...om/default.aspx
Where is located this ODB2 connector on our cars?
You can monitor the coolant temperature just by pressing the trip reset button the correct way the correct number of times. There's a knack but once you can do it menu 7 shows the coolant temperature in degrees C. It's the best way to monitor the coolant temperature when driving.
Google or search the site for "hidden menu".
My Ride: Bmw 530d 2004
Hidden menu
- Antti -
Thanks for all the links folks!
thesalboy
04-08-2015 09:13 AM
JonathonK
03-11-2015 03:13 PM
