Concern over Upper Timing Chain Crack
Old Oct 3, 2018 | 12:03 PM
naenyc's Avatar
My Ride: 2004 BMW 545i
Engine: 545i
Default Concern over Upper Timing Chain Crack
Alternator moved to right hand side.
Crack up Upper Timing Chain
First, I can confirm that it is possible to access the upper timing chain bottom bolt on a 2004 545i with active steering. Photo attached.
As stated in other threads:
  1. Lossen Serpentine Belt
  2. Remove top bolt
  3. Loosen bottom and slide to right.
Upon removing the gasket, I noticed what seems like a crack, and not sure if it is significant. If not, do I simply apply a little gasket sealant over it?
Thanks
cRaCkZzZz
Jul 12, 2021 07:53 PM
twidge
Jan 21, 2016 01:42 AM
Mikethepanel
Mar 8, 2013 07:40 PM
sailorbill
Mar 29, 2010 09:34 AM
Arrow
Jun 1, 2009 07:07 AM
