Complete Electorical Systems failure
Old Jul 31, 2010 | 12:01 AM
shurick's Avatar
So I'm driving home and all of the sudden I see christmas trees on my dash light up.
This is the strangest thing I've ever seen. The guages won't respond normally, they haphazardly swing. My wipers automatically turned on and wouldn't turn off. My blinkers won't work. The Idrive display showed some messages, now its completely blank. The 2 displays on the dash keep cycling every indicator I've ever seen. Weird stuff like that is going on all of the sudden.
Has anyone seen anything like this before? This is on a 2004 530i 6pd.
Thanks,
Alex
Old Jul 31, 2010 | 02:38 AM
billeul's Avatar
Yes, battery related, ie battery, IBS(negative battery cable), SBT(positve battery cable) or something in charging system.
Old Aug 6, 2010 | 06:39 PM
forever5's Avatar
Thanks,
Alex
Check for any water in the trunk; in the battery box. If so, it will cause all kinds of elec problems.
Either that or a random UFO in the area.
Old Aug 6, 2010 | 09:12 PM
5-string's Avatar
My Ride: 2004 545i Sport - Silver-Grey, Nav, Active Cruise, HUD, sport seats, Logic-7, charcoal filter mod, Euro reflectors, hard-wired V1
A few weeks ago I actually had a warning message pop up that said something about "Electrical Failure". The message went away after a few minutes of driving. I also think it was UFO-related.
Old Aug 6, 2010 | 09:33 PM
shurick's Avatar
It was weird. That evening the car was completely possessed. The next morning it was like nothing happened. <shrug>
Old Aug 7, 2010 | 04:45 AM
luigi524td's Avatar
Definitely check the trunk / wheel recess for signs of leaking into the electronics.
Old Aug 10, 2010 | 06:28 PM
hmuchmo1's Avatar
well i can tell you my story of a similar experience with my 04 545i.
simply driving down the road and get the xmas tree of lights, until i would get the gear indicator and have to pull over.
all i had to do was wait about an hour and I could get in and drive away, so it would happen quite often.
so went to local bmw repair, and they replaced the alternator. that worked for about 2 weeks till it started happening again.
had bmw replace the battery, didnt fix it, then had the other shop replaced both battery cables, still didnt fix it.
then had integrated supply module replaced, still not working.
so i took it to another shop, they immediately said alternator, explained the current one was brand new, but the insisted it was the alternator because they hooked a recording volt meter to the car and as it would run over time the voltage would drop from 14.7 to 11.2.
I explained the warranty company would not cover another alternator, but they said they would look deeper and talk to them.
end of the story is that my front valve covers were leaking oil and it was landing in the alternator, and because synthetic oil is conductive it was shorting the diodes dropping the voltage and therefore causing the lights.
they fixed the valve covers and got a new alternator, now all is well.
so hopefully all this info will give you plenty of place to look for problems.
BurtonSnol3order
Jul 3, 2015 09:28 PM
kentuckynet
F10 Discussion
Jul 3, 2015 06:14 PM
shervinj
Jul 2, 2015 07:29 PM
lukieno1
Jul 1, 2015 04:37 PM
RobR
Jun 2, 2015 08:31 AM
