Comfort Seats' Headrest Wings INOP
Old 01-03-2018, 08:36 AM
lem0n's Avatar
My Ride: 2008 E61 535Xi
Default Comfort Seats' Headrest Wings INOP
Hello,
I recently noticed that both headrest "wings" on driver/passenger seats are not staying in place once you angle them to support your neck. Does anyone know how these work internally or have tried to fix them?
Picture below shows the position they should stay in and while mine can be adjusted to this position but spring back immediately and don't stay in place.
Thanks!
Old 04-19-2018, 03:04 PM
lem0n's Avatar
Bringing this back up from the dead, in case someone knows anything about this.
Old 04-19-2018, 07:57 PM
stel_i79's Avatar
My Ride: 530i N52
Engine: n52
[QUOTE=lem0n;1593190]Hello,
IS THIS YOUR CAR????
were is the sunroof ?
did u manage to fix it?
Old 04-19-2018, 08:04 PM
lem0n's Avatar
Nope, not mine; simply found the picture to illustrate the issue. Bet it’s a European model and not even a wagon.
And no, still haven’t found a solution to the problem, hence the bump.
Old 05-26-2019, 12:25 PM
n3rdk1ng's Avatar
My Ride: 2005 530i
I just retrofitted some comfort seats into my E60 and ran into the same issue. Has anyone figured this out yet?
Old 05-27-2019, 07:32 AM
lem0n's Avatar
I’ve given up and drive the car as is without the headrest wings. If you find a cure, do post it here please.
Old 05-27-2019, 12:11 PM
n3rdk1ng's Avatar
My Ride: 2005 530i
Hey lemon,
I ended up taking apart the passenger side and made up a fix. I’ll write up a detailed post with pics and post it here when I get a chance. I have the pre-lci seats with the smaller wings, but it should be the same for the newer LCI style headrests. BMW used a foam rubber type ring to hold the wings in place with friction. I simply removed the cover and cut a small piece of vacuum hose to put in place of the foam ring. It works perfectly.
Old 05-27-2019, 01:25 PM
lem0n's Avatar
That would be great! I would love to fix mine.
Old 06-08-2020, 03:19 AM
M5Bob's Avatar
My Ride: E60 M5
Originally Posted by n3rdk1ng
Hey lemon,
Hi, Di you every manage to post the fix? Im having the same issue with both front seat headrests. Tried to take the back headrest cover off but it doesn't want to budge and im afraid to force it for fear of damaging something. Thanks!
Old 06-08-2020, 07:14 AM
n3rdk1ng's Avatar
My Ride: 2005 530i
It totally slipped my mind. I will try to do that this week! Do you have the LCI headrest or the Pre-LCI headrests?
Quick Reply: Comfort Seats' Headrest Wings INOP
