coil-over installment question
Old Sep 18, 2015 | 09:17 AM
keno75's Avatar
My Ride: 2008 550
Default coil-over installment question
Good Afternoon, I got a question that's brewing in my mind and wanted to make sure I will be ok for this project. I came across some brand new KW V2's coilovers and wanted to get this installed soon. My question is with installation, I am currently running a Micro's 111 (20X8.5 ET18 front) and (20X10 ET25 rear). Tire series are 245 fronts and 275 rears. Will everything clear properly with the KW coiler and my current tire/wheel setup? Im not sure if I will need to installed spacers or not.
For the guys/gals who have installed KW V2's already, were there anything else needed with the installed or something I sure replaced while doing this installation. The coiler are still in the box they came in, so I haven't really inspected them yet. Thanks in advance
Keno
Old Sep 18, 2015 | 06:21 PM
JDeezyNYC's Avatar
My Ride: 2008 535i
Hey
Keno
All depends on wheel offset and ride height. The wheeel wells are not very big on these cars. Use the search feature and check out some pics of members rides to see.
Old Sep 20, 2015 | 11:29 AM
RIHI's Avatar
My Ride: BMW
I had already purchased wheels and spacers and had them on my E61 with the original suspension. I purchased a set of coilovers from JRZ (so I cannot speak for the KWs) and installed the same wheels and spacers I had with the original suspension.
So I would say i am almost certain your wheels will fit with the new suspension.
Old Sep 22, 2015 | 10:56 PM
keno75's Avatar
My Ride: 2008 550
Thanks a lot fellas for your input...
Keno
Old Sep 23, 2015 | 02:19 PM
vince_e60's Avatar
My Ride: ACS E60
you will almost always need spacers when you install coilovers with aftermarket wheels. keep that in mind.
Old Sep 24, 2015 | 06:47 PM
keno75's Avatar
My Ride: 2008 550
Thanks Vince....now to figure out what size I will need ha
socale39
Sep 5, 2023 08:30 AM
windnsea
May 25, 2015 09:49 PM
carid
Apr 29, 2015 04:20 AM
b1mmerbob
Apr 17, 2015 11:41 AM
brian1225
Apr 16, 2004 05:59 AM
