Coding rear parking (tail) lights as DRL?
So I've upgraded my light module to a LM2 and have recently coded my angel eyes to run as a DRL (ie. the angel eyes switch on when the light switch is on position 0). My question is, is it possible to code the rear parking (tail) lights as a DRL so that they turn on when the light switch is on position 0? To clarify, I would like the features that turn on when the light switch is on position 1, but I want to use position 0 instead of position 1. That way, I don't get that stupid gong when I leave the car and forget to turn the light switch from position 1 to position 0 (or 3).
If it helps, my car is a 09/2004 E60 525i and I have retrofitted LCI tails with Bruce Miranda V6.11 cables
Thanks!
Thanks!
Have you tried one of these?
DRL_TFL_BLK_V_GED
nicht_aktiv not active
aktiv active
DRL_TFL_KZL DAYTIME RUNNING LIGHTS (DRL) - LICENSE PLATE LIGHTS
aktiv active
DRL_TFL_RL_BL DAYTIME RUNNING LIGHTS (DRL) - TAIL LIGHTS
aktiv active
DRL_TFL_RL_BL_1_33 DAYTIME RUNNING LIGHTS (DRL) - TAIL LIGHTS 1
aktiv active
DRL_TFL_RL_BL_2_33 DAYTIME RUNNING LIGHTS (DRL) - TAIL LIGHTS 2
aktiv active
DRL_TFL_SML_33 DAYTIME RUNNING LIGHTS (DRL) - ANGEL EYES (LINKED TO [VERHALTEN_DRL_TFL_33])
aktiv active
DRL_TFL_TFL_33 DAYTIME RUNNING LIGHTS (DRL) - DAYTIME RUNNING LIGHTS
aktiv active
DRL_TFL_BLK_V_GED
aktiv active
aktiv active
aktiv active
aktiv active
aktiv active
aktiv active
aktiv active
DRL_TFL_BLK_V_GED
aktiv active
aktiv active
aktiv active
aktiv active
aktiv active
aktiv active
aktiv active
DRL_TFL_BLK_V_GED
aktiv active
aktiv active
aktiv active
aktiv active
aktiv active
aktiv active
aktiv active
I had posted this thread on the bmwcoding forum, and user toad had advised that you needed to switch the following functions to activ.
DRL_TFL_RL_BL
DRL_TFL_RL_BL _1_33
DRL_TFL_RL_BL _2_33
Worked like a charm!
Really appreciate your reply though!
My Ride: 2004 Dinan 545i, Titanium Metallic Silver, 2007 Dinan M5, 6sp, Silver Gray Metallic
I really would like to get a better handle on learning how to code my car.
socale39
09-05-2023 08:30 AM
rizwan1377
04-05-2015 05:22 PM
andymax
03-13-2015 10:51 AM
