Coding needed for wheel / tire change?
Model Year: 2010
I was looking at upsizing my wheels from 18" to 19":
245/40R18, 60.0 mph
to:
245/35R19 front, 59.9 mph
275/30R19 rear, 60.5 mph (BMW-recommended, available for my preferred tire model)
The better match for the rear seems to be:
285/30R19 rear, 59.9 mph (not available for my preferred tire model)
For proper operation of the vehicle functions: speedometer, DSC, ABS, ASC, Corner Brake Control, Dynamic Brake Control, Brake Fade Compensation, Brake Standby, Brake Drying, etc, is it critical to go with BMW specified front and rear wheel / tire sizes and code the vehicle with the correct / compatible wheel types?
Vehicle coding options include wheel types: All BMW Options
Is the wheel coding for the vehicle a functional technical parameter, or a non-functional inventory label?
245/40R18, 60.0 mph
to:
"The 5 Series brake system is supported by the comprehensive functions of Dynamic Stability Control (DSC). These include antilock braking (ABS), Automatic Stability Control (ASC), Cornering Brake Control and Dynamic Brake Control; each of these functions contributes to vehicle stability and some of them do so specifically during braking. Other braking enhancements via DSC include Brake Fade Compensation, which compensates for loss of braking power (fading) under hard or repeated brake use; Brake Standby, which snugs the brake pads up to the rotors upon sharp deceleration to reduce inherent lag time in brake application; and Brake Drying, which brings the pads to the rotors periodically during wet-weather driving to keep the brakes ready."
My Ride: Sapphire Black 07 530i non-sport
7000k Angel Eyes
6000k HID Xenon adaptive turn Head lamps and Fogs, Clear LED Turn Signals front/back and side markers. Clear bright license plate lamp. Full interior lighting upgrade.
Coding: daytime angel eyes, auto windows up, and digital speedometer. (Thanks to John at Motorcepts.com)
OEM Tinted LCI Tail lights (Thanks to David at http://www.luxmotorwerks.com
Oem Mtec rear bumper with diffuser and M5trunk finisher
Debadged! The best paint work! (Thanks to Desimone BMW)
20x8.5 +18 20x10 +25 Concept One RS-8 Black Machined Chrome Lip
V6.1 cables (Thanks to Bruce Miranda)
Nitto Invo tires 285x30 R20 - 245x35 R20
Discounttire.com
Vac Motorsports ecu chip upgrade, and fender roll
http://vacmotorsports.com/
wish list:
Rieger Front bumper
Hamann side skirts
Custom quad exhaust
Rpi Ram air intake scoop
M5 SMG shift knob
KW Variant 3 suspension
Brembo Big Brake kit
LCI Heads
Tints
BMW M5
245/40R18, 60.0 mph
to:
245/40R18, 60.0 mph
to:
Yes, it is mandatory at the time of installation and when iDrive reports tire wear too. OH ... very very important ... only BMW air should be used to inflate the tires
Seriously, where did you find that information?
I suppose if the rolling radius of installed wheels was changed drastically I suppose it might be possible to code and correct' the speedometer so that it reports your speed more accurately.
Virak1985
Jun 16, 2015 12:24 AM
