COBB AccessPort v3
Old Mar 20, 2015 | 08:00 AM
mishka69's Avatar
My Ride: BMW 535i 2008
Default COBB AccessPort v3
I just get COBB V3. Try to flash my 2008 535i. While flashing error codes start come up, and very serious like transmission problems ....After flash I uninstall everything, no more error codes. Scan for error COBB and no errors found,
Need somebody help over the phone to flash my car.
Old Mar 20, 2015 | 12:26 PM
biz77's Avatar
That sounds pretty standard for a Cobb flash while the flashing process is taking place. Did you let the AccessPORT finish flashing? Did you try starting the car after the flash or did you just unmarry the AccessPORT from the car?
Common and perfectly normal occurrences while doing the initial flash and during MAP changes with Cobb:
All radio and chime sounds disappear for the first 25% of the process and then return for the remainder.
Center gauge cluster shows yellow ! warning
iDrive screen will show various warnings including car on lift and AWD system malfunctions.
Old Mar 20, 2015 | 03:32 PM
skrelnik's Avatar
My Ride: 2010 535i xdrive
Model Year: 2010
This is 100% normal for error codes to pop up during the install. Just let it play out, and after roughly 20 minutes it will be done. Note that while you are flashing the car, all doors should be shut, do not open doors or windows during the flash...just sit patiently in your seat and read a book or your phone. After 20 minutes or so it will be good to go...then unplug the Accessport and start driving.
Which map are you installing? Do you have any mods on your car?
ADD
Oct 15, 2015 07:52 PM
nuklep
Aug 7, 2015 06:42 PM
Kbc
Jul 31, 2015 10:07 PM
ModBargains.com
Jun 16, 2014 03:42 PM
ModBargains.com
Jul 19, 2012 08:51 AM
