Clutch Qestion
#21
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
O.k. Guys, today I got my car back. My clutch was shut. flywheel was undamaged. Just drove the car for few miles and the clutch feels soft than it was before. Engagement somewhere in the middle. I replaced the unlock valve also but after driving it back home did not notice a bid deference in first and second gears as others have described here. probably need to get used to it. Here is the list of parts just in case if someone encounters clutch problem. once the transmission is out I decided to replace other parts as I am going to keep this car for few years and do not want to pay same money just for labor again
21207546375 clutch kit, Includes pressure plate, clutch disk and bearing $340.51
11147512101 main shaft seal $72.46
11147504376 end cover $45.18
22316773825 transmission mounts $ 15.36 each you need two
26117546425 Universal flex disk $116
21526775924 clutch slave cylinder $61.32
83220406941 transmission fluid 5 liter container $157.20 only took 2 1/2 liters
26127521856 drive shaft center mount $ 60
parts total $930, labor $1150
Total cost around $2100
I think it is good idea to get all the parts your own and bring it to the shop that way you know that they putting original parts and not making money on the Parts also.
Now I have question for experienced manual drivers. I start driving from the second gear most of the time and leave out first. and sometimes move from second to sixth when traffic is moving slow. Is this normal or this will damage my clutch again, Is it ok to leave out some gears when not accelerating hard?
#22
Model Year: 2005
Oh and for those people who hesitate to change transmission and differential so called "lifetime" oil after seeing my old transmission oil I say definitely do it . It was like a black coffee.
I still like to hear your opinion about leaving out some gear when driving manual will hurt clutch or wear out other parts. Or I have to go through all the gears anyway. I doing it to save little bit of gas when traffic's moving slow.
Thx
Thx
#23
#24
Model Year: 2005
Thanks, that's what I was thinking but was not quite sure
#25
My Ride: 2008 BMW 535i manual Monaco Blue-Sport Package-Cold Weather Package-Premium Package-Heated Rear Seats-PDC-Ipod Connectivity
#26
My Ride: 2004 530isport packagepremium packageactive steeringxenon hids20mm H&R spacers in the rear6 spd51kpurchase price , 32k back in 2006
Model Year: 2004 530i
thanks for all the information !
two questions :
what was the condition of your drive shaft center mount , along with the two transmission mounts , were they cracked or broken?
are these parts and prices for oem or aftermarket parts?
thanks again!
#27
Model Year: 2005
All Parts and prices are OEM. the parts condition you mentioned where OK but as I am going to keep my car for a while I thought they will get bad sooner or later an I decided to replace them once everything is out.
PelicanParts.com
09-10-2015 10:02 AM
PelicanParts.com
08-13-2015 01:45 PM
