Clutch pedal squeak
Old Apr 26, 2006 | 10:44 AM
slowdog's Avatar
Well, the clutch pedal on my 545 is starting to develop a squeak when I release the pedal. Just like my E36.
Does BMW have a real fix for this or will the dealer just spray some lube on the pedal bushings--likely to last a couple of weeks before the noise comes back.
If not, I guess I'll have to have and independent install a set of UUC bushings. I doubt a dealer would do the job and I can only imagine what they'd charge.
Pieter
Santa Monica, CA
Old Apr 26, 2006 | 10:46 AM
my530i's Avatar
WD-40
Old Apr 26, 2006 | 11:12 AM
slowdog's Avatar
On my E36, the dealer lubed the pedal a number of times, and the squeak always returned within weeks, if not days. The UUC bushings were a good solution. I was hoping that by now BMW had come up with a proper fix for the problem--it seems to run across the model range.
As a sidebar, I'm not a big fan of WD-40 as a lubricant. It tends to attrack dust and not really last very long. (For most applications, I like Boeshield T9)
Old Oct 20, 2006 | 08:47 AM
LukeV's Avatar
Sorry for the stupid question: what do you mean with "UUC bushings"?
Old Oct 21, 2006 | 11:13 AM
nicke60gre's Avatar
UUC bushings
LILBZ3
Sep 27, 2015 08:06 PM
PelicanParts.com
Sep 10, 2015 10:02 AM
Alan111
Sep 9, 2015 07:42 AM
ST JAMES
Sep 4, 2015 04:54 PM
PelicanParts.com
Aug 13, 2015 01:45 PM
