Climate issues
My Ride: Yes
Climate issues
So I have one of the more rare errors with my E60 I believe, I have the exact problems as described here:
https://5series.net/forums/e60-discu...e-help-145078/
https://5series.net/forums/e60-discu...e-help-145080/
Was planning to replace the evaporator temperature sensor as it seems a faulty one does some of what is actually broken with my climate system (sudden changes in temperature) However, does anyone know where to find this one?
Take a look at: realoem.com Go in and enter your ven number, then look under Heating and Airconditioning.
My Ride: Yes
Does this mean it sits at the hazard light button aproxomately?
Believe you might have to remove the center trim piece and the CCC unit behind it. There is a you tube clip on removing the CCC. I have pulled my CCC unit to have the navigation system repaired couple years ago. Not a bad job.
Take a look at this site, bmw navigation radio cd changer repair
Go in and look at the e60 segment. There is a link to the you tube vidio on removing the CCC unit. Believe this may put you where you want to be for the temperature sensor #3.
Have you read the error codes for the HVAC system? A good OBD BMW specific code reader, like Carly for BMW or one of the laptop software packages should give you a clear picture of what is wrong, be it sensor # 2 or #3 that is bad. Could even be a restricted thermal expansion valve restriction.
God luck.
God luck.
Brendan412
10-22-2015 04:19 AM
