Climate control
This may seem like a stupid question.....
is this just a standard heater control unit or is it climate control? If its not can i just replace this unit with the climate control facia and have the function of climate control or do i need other parts?
Then there is an extended climate control available, but you can not swap the control unit straight on. It would need lots of (expensive) work to fit. There's a thread on the forum where an extended climate control is installed on a car which used to have the standard climate control. You should check it for more information.
edit: Here it is https://5series.net/forums/index.php?showtopic=91175
- Antti -
EuropeanArtz
Sep 23, 2015 08:21 PM
bimmerspeed
Frequently Asked Questions
Sep 1, 2015 05:09 PM
