CIP 18 vs. CIP 17 vs. CIP 16
My Ride: 545i Mystic Blue/Black Leather Type 124 Wheels
Originally Posted by eggz' date='Jul 16 2005, 10:30 PM
[quote name='Iceman' date='Jul 16 2005, 05:54 PM']
2A9A Cam sensor, inlet signal ? signal invalid for synchronization
2A98 Crankshaft-inlet camshaft, correlation- Value outside reference range
2A82 VANOS intake- stiff, jammed mechanically
2A9B Cam sensor, exhaust signal ? signal invalid for synchronization
2A99 Crankshaft- exhaust camshaft, correlation- Value outside reference range
2A87 VANOS exhaust- stiff, jammed mechanically
![Ermm](https://5series.net/forums/images/smilies/imported/ermm.gif)
[snapback]149904[/snapback]
[/quote]That was just for some of the new N52 engines that has a rough running problem and showed those error messages
Banned
Originally Posted by EBMCS03' date='Jul 16 2005, 08:38 PM
[quote name='clived' date='Jul 16 2005, 08:24 PM']I've experienced that - when the steering wheels move into place when starting the car, it just doesn't move to where it should, leaving you to move it manually - simple really ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
[snapback]149900[/snapback]
[snapback]149908[/snapback]
[/quote]That's not the issue I have (although upon re-reading the description, it's likely what they're referring to). My steering wheel is off center--when driving straight it points a few degrees to the left. When they installed 17.01 with my aux input install, it was way off (pointing to 11:00 instead of 12:00) and they had to reset AS, but now it's about 1/3 as much off center and I don't notice it all the time--so that's what I thought it was referring to.
My Ride: G30 M550i
Model Year: 2018
Originally Posted by stream' date='Jul 17 2005, 10:31 AM
That's not the issue I have (although upon re-reading the description, it's likely what they're referring to).? My steering wheel is off center--when driving straight it points a few degrees to the left.? When they installed 17.01 with my aux input install, it was way off (pointing to 11:00 instead of 12:00) and they had to reset AS, but now it's about 1/3 as much off center and I don't notice it all the time--so that's what I thought it was referring to.
[snapback]150003[/snapback]
As far as the problem I'm seeing with the steering wheel, and I remember a post about it here many moons ago, is that the wheel creeps down from the memory postition over time. Every so often, I'll get the feeling the wheel is too low and I'll press the memory button on the seat and it'll move back into the stored position. After a few days, it'll creep back down (and no, I'm not adjusting anything, I'm the only driver, using only one key, etc.)
Banned
Originally Posted by Rudy' date='Jul 17 2005, 08:53 AM
[quote name='stream' date='Jul 17 2005, 10:31 AM']That's not the issue I have (although upon re-reading the description, it's likely what they're referring to).? My steering wheel is off center--when driving straight it points a few degrees to the left.? When they installed 17.01 with my aux input install, it was way off (pointing to 11:00 instead of 12:00) and they had to reset AS, but now it's about 1/3 as much off center and I don't notice it all the time--so that's what I thought it was referring to.
[snapback]150021[/snapback]
[/quote]They reset AS when I brought the car back after I noticed the steering wheel being way off center after 17.01 installed. Seemed fine for a few weeks, but now it's slightly off center.
![Angry](https://5series.net/forums/images/smilies/imported/angry.gif)
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
[/quote]Ah.... Well I have two drivers for the car so two sets of memory are being used... I have had to "readjust" the wheel before but never thought twice about it since I figured some stupid memory got messed up and it wasnt a big deal... Now that I read it... Hummmmmmmmmmmmm somthing to keep in the back of my head.
My Ride: F02 LCI Individual
Model Year: 2013
My car drives so much better now.
AS is improved, tranny is improved, the HUD is moved up, waaaay better to see, the new windows make the car so nice... The rattling noise is gone when AS wakes up upon unlocking the car...
Just a couple problems left:
Don't know how long the battery will last this time,
Next entertainment source button on steering wheel still doesn't circle through all sources,
ACC stalk doesn't work as it should.
Over al, I am so happy to have my car back. The 525d loaner made me seasick.
My Ride: 530d (Jan 2005) premium pack, pro nav, steptronic
Originally Posted by E60Speed' date='Jul 17 2005, 01:27 AM
Who is going to be first with CIP 19.0 info ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
[snapback]149854[/snapback]
Model Year: 2005
Engine: 545i
Over al, I am so happy to have my car back. The 525d loaner made me seasick.?
? ![Wink](https://5series.net/forums/images/smilies/imported/wink.gif)
[snapback]150104[/snapback]
Good info !
Model Year: 2005
Engine: 545i
Originally Posted by ls78000' date='Jul 18 2005, 04:56 PM
[quote name='E60Speed' date='Jul 17 2005, 01:27 AM']Who is going to be first with CIP 19.0 info ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
[snapback]150272[/snapback]
[/quote]From what I understand - can't be long now...
Model Year: 2013
Isn't 19.0 supposed to provide MP3 for NAV cars ?
19 will come soon. The MP3 will not come before September!
