Check engine light
Old 04-17-2012, 08:19 AM
528iFLYguy's Avatar
So Im trying to figure out why my check engine light comes on seemingly when my gas gauge gets low. I noticed the check engine light on sunday and planned to take to the dealership monday, but when I put gas in it, it went off. So today im down to about 31 mls till empty when lo and behold the check engine light comes on again. Could this be a sensor issue or what. I always put 93 in her and shes not due for an oil change till June. Give me some insight Gang
Old 04-17-2012, 08:40 AM
EddieboyS's Avatar
My Ride: 2006 550i, 6 speed manual
Interesting, I've got something similar happening occasionally with my 06 550i. I always user premium fuel as well.
Old 04-17-2012, 05:30 PM
AchtungE60's Avatar
My Ride: E60 530i
You sure its not the fuel light? I wouldnt worry about it. You'll probably never be able to find out. just keep it fueled.
Old 04-17-2012, 08:59 PM
toyota2bmw's Avatar
Sometime the seal on the gas cap wears prematurely and cause the light to come on. The sensor throws a fault when there's not enough pressure in the fuel delivery system caused by a loose gas cap. New gas cap = $20.
Old 04-18-2012, 04:27 AM
l1tech's Avatar
My Ride: 528
Model Year: 2009
What you are referring to would be considered an evaporative system leak. This happens when the fuel tank does not hold pressure or vacuum. This has absolutely nothing to do with fuel delivery.
Old 04-18-2012, 05:47 AM
best1's Avatar
My Ride: 2008 550i M-Sport
i had a similar problem except mine was more random and had nothing to do with the fuel level. i replaced the gas cap and that did not fix it. dealer pulled the code for me and it was one of the oxygen sensors. It took me 30 minutes to replace and everything is fine again. 2008 550i
Old 04-18-2012, 07:25 AM
syrousd's Avatar
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
O2 Sensor was at fault on mine as well......
DavaiLave
08-02-2022 02:16 AM
gergnang
02-02-2021 07:29 AM
Stranger12
04-05-2015 10:42 AM
Sic Sticks
03-30-2015 01:17 PM
laz1left
03-11-2015 11:15 AM
Quick Reply: Check engine light
