Changing tyres to SP9000 different profile, Advice please
Old May 31, 2007 | 02:21 AM
southerncomfort's Avatar
Hi
Me again
I have been advised by more than one source that if I change my tyres from Conti Sport Compact 2s (which are apparently quite firm/noisy) to Dunlop SP9000 with a slightly higher profile (which are apparently quite soft/quiet) that the ride is much better?? Will this affect my warranty or cause any undue DSC problems.
Old May 31, 2007 | 03:47 AM
den535d's Avatar
My Ride: 535dSE - Amethyst Grey, No model insc, standard wheels, Dynamic Drive, Rear side airbags, Auto-dim ext & int mirrors, Myrtle wood trim, Amethyst-Exclusive Leather, Heated front & rear seats, Active front seats, Electric comfort seats, Visibilty Pack, Pro Sat-Nav with TV, Bluetooth, Sun Protection glass.
I can't see how it would affect your warranty, but if you're going from RFTs to non-RFTs you'll see a big improvement in ride quality and noise. Tramlining will disappear too. A change in tyre aspect ratio will affect your speedo and odometer accuracy, because you're changing the radius of the wheel/tyre combo; although I'm not sure if that can be corrected with the car's on-board software. Why do you want to change the profile of the tyre? There are loads of good makes available with the same ratio as the standard fitment. I'm guessing that going from an RFT to a taller non-RFT set-up is also likely to make the handling a lot sloppier than you've been used to.
Old May 31, 2007 | 04:45 AM
Thanks for reply.
They are actually NON R/Fs at present, but low profile and seem hard. So it will still be NON R/Fs in the Dunlop range, but next size up on the wall size (i.e 30 and 35, will now be 35 and 40) - good point about the mileage though? how do I find out about this, or will it be much diff?
madein
Jun 6, 2015 11:48 AM
JHR-5
May 11, 2015 06:23 PM
kskane
Apr 23, 2015 12:56 PM
Daniel_gnt
Apr 20, 2015 06:37 PM
bananfiu
Mar 14, 2015 02:08 PM
