Changing (OEM) Xenon tot Bi Xenon
My car has the original BMW Xenon headlights (non adaptive).
Does anybody know if it is possible to;
1. Swap the single Xenon headlights for Bi Xenon headlights
2. Swap the single Xenon headlights for Adaptive Bi Xenon headlights?
Read some posts about retrofitting from halogen to Xenon but I could find none covering stock xenon to bi-xenon.
Contact your dealer.
The basic Bi Xenons are only a two light system that moves a cover up for the hi-beams.
I have xenons and have adaptive headlights (that moves as you turn), do I have bi-xenons? Sorry I was never sure about this as I'm the second owner bought at a auction so not 100% sure about the original equipment that came with the car.
Thanks
Originally Posted by jagbagri' post='763352' date='Jan 8 2009, 09:54 PM
What's the difference between the xenon and Bi-xenons.
Thanks
Thanks
Oh, and Yes - It is 100% possible to retrofit, but you will probably need new headlights - I doubt it would be cost effective. Might be cheaper to retrofit an aftermarket HID system into the inside lens assembly to use as brights - unless you have daytime running lights, don't do it because you will ruin your ballast.
I didnt kn I had bi-xenon, one night I was trying to use my high beem, and I was like, cool my high-beem has xenon too, little did I kn I had bi-xenon and it was comming from the regular highlights.
Originally Posted by anit999' post='764284' date='Jan 10 2009, 01:55 PM
All E60 xenons are bi-xenons. For high beam a shield is moved in the xenon projector to give a brighter light but the inner halogen bulb is lit.
socale39
09-05-2023 08:30 AM
