changing headlight bulbs
My Ride: G30 M550i
Model Year: 2018
The owner's manual shows a pretty simple process for changing the bulbs for the standard headlamps. The Xenons, however, are supposed to be replaced by the dealer due to high voltage, etc.
Does that answer your question?
I've replaced my xenons previously. Its really difficult as you will have to remove the bumper first in order to reach the screws for the headlight ass'y. Headlight ass'y has to be removed in order to replace xenons due to space constraint.
AFAIK, the entire headlight asembly would need to be removed to change the xenon lamp
There is simply not enough room behind where the holder is supposed to be.
And, in order to remove the headlamp assembly, the bumper has to be removed so that there is access to the screws
Edlee, one of our forumers, had his xenons changed and shared this info in one of our meetups
[snapback]119383[/snapback]
I changed my OEM xenon bulbs without remove the bumper!!
[snapback]119508[/snapback]
socale39
Sep 5, 2023 08:30 AM
Tsoup
15
Dec 20, 2021 11:14 AM
Sai Paladugu
Mar 23, 2015 01:23 PM
