Changed thermostat, now overheating??
#21
If someone wants to test their thermostat that is bad they can just stick it in a pot of water, let the water boil to test it - distilled water only of course. (that was a joke, you're only TESTING it)
#23
If you are having the same problems that i was having, then i would recommend removing the thermostat and just putting the housing back on. I replaced the oil separator a few months back due to the diaphram splitting inside. symptoms was constant 02 fault codes due to diaphragm causing a massive air leak making the car rough idle and bad mpg. When i got the engine light back on a few days ago i had the P0599 heater circuit plus the 02 codes. I thought i had another air leak pus the thermostat problem, although now ive put the thermostat housing back on and cleared the codes, im not getting any codes whatsoever. So i presume that the bad thermostat was causing the other codes as well.
Like i said i will keep you updated when i fit another thermostat to see if my problem is electrical.
#24
My Ride: 2005 E60 525i at
Hey guys. I am experiencing about the same problem on my 2004 525i. My wife was driving around when it suddenly overheated. I later found out that the fan was not functional. But when I disconnect the wire on the bottom left hose of the radiator the fan turns on. But still,the care overheats, am starting to suspect the thermostat now.
#25
Here is the page from the Bentley manual:
What made you replace the thermostat in the first place? Perhaps your water pump is spent??
#26
My Ride: 2008 550i & 2009 X6 35i
#27
Here's another one for you guys, not to intrude on the thread, just didn't want to create another thread:
1. Over heat indicator goes on, radiator fluid is at max.
2. Fan is working properly, turns on and activates when hot.
Prior to overheat warning: when the heater is turned on with the car in motion, it blows warm/hot air. After a few minutes, suddenly the air becomes cold followed by the over heating warning messages.
