Changed starter, now car makes weird noise
My Ride: 535i M / X-Drive
Model Year: 2010
Engine: N54
Starter was dying on me few months ago.. kept hitting the solenoid with a little tool and it would start the car up a few times till it completely died on me.. finally got around to changing the starter myself, I have a used one and a rebuilt one I got for 120$.. tried both starters and same weird a** noise leaving me clueless.. I tried to test without the intake back on, just to see.. but both starters seem to give me the same weird noise.. I should mention before I took out the old (original) starter I had on that died on me, it wouldn’t click or crank or nothing at all.. some1 plz tell me if u know what’s going on.. I know the starter is secure and placed on property, but worried maybe it’s dead or the flywheel got damaged idk anymore I’m all out of ideas
Thanks in advance
Here’s the video.. hopefully u can hear the weird ass “vacuum-like” noise it makes lol sorry for the quality![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
https://youtube.com/shorts/UG5TcwjnN94?feature=share
Thanks in advance
Vacuum-like sounds more like a hose. There are a ton of brittle hoses in that area that are easy to crack. I cracked one clean when I replaced my Starter.
Model Year: 2010
Engine: N54
Model Year: 2010
Engine: N54
If it isn't turning, more than likely the starter solenoid isn't working right. Part of its job is to push the gear out to engage the flywheel. If it isn't doing that, it may seem like something is happening inside the starter, but not all that needs to happen. If that's the case, I'd say that maybe the ones you put in are not working right.
BTW, as some others have suggested here or on the other forum, it could be a weak ground. Check the ground strap over on the right side under the car. Braided bare metal strap. If it is all green and brittle, it may be broken enough to not be able to give enough juice to actually operate the starter properly.
Killaduce (01-31-2022)
Model Year: 2010
Engine: N54
here are the errors INPA gave me earlier.. keep in mind some may be due to the battery dying on me before I went and replaced it with a brand new one a few weeks back, and others maybe cuz the car has been sitting for few months now
CAS - A0B4 (common error when car doesn’t start I take?)
CAS - A0B1 (could be caused because I put in a screwdriver, to put it in neutral to let it roll back a tiny bit)
few dme errors involving the throttle being disconnected still and boost pressure control etc. (Nothing major enough to cause the weird noise and no start I don’t think..)
DSC - 5EBA
DSC - 5F77 (one of these two errors is the steering angle sensor if I’m not mistake, which needs to just get recalibrated/re-aligned which I can do once I start the damn thing lol..)
Now.. I think the scariest errors in getting is for the tranny
one of these two errors keeps coming back even after being cleared which if I’m not mistaken, is my first error I’ll mention:
EGS - CF2B.. & the other one is..
EGS - 507D..
any1 ever see any BS this ridiculous
Don't get concerned about the transmission codes yet. These are often thrown when there are issues starting and with the crankshaft position sensor.
