change Halogen To Xenon! E60 2004
Hate to break it to you. Its not gonna work. If you really want xenon, just buy after market bulb/ballast/cable cancellor and you are good to go.
It is too much work, time, money to install oem projector headlight housing, reprogram, etc.
Originally Posted by medik13' post='999800' date='Sep 6 2009, 04:24 AM
Why won't it work??? There are members on here that have done it succesfully! Just do a search! It consists of splicing a few wires and connecting a capacitator. No reprogram needed!
I know it works! But nobody give me an answer to the what wires I need to tie together? Please some one HELP
Did you even read post #6 up above? You also might wanna try the search function on the upper right corner of your screen ...
I am planning the same retrofit. I know you have to cut the green wire then connect one end to the white and one to the gray. Then put a capictator in between the brown and the yellow wire. Then wire the angel eye wire to another wire. You cannot makethe Adaptive feature work andyou have the level the lights manually. This is what I have put together. There is a post that gives the info in detail. you just have to look for it. When I receive the lights, I will be posting all about it.
Yeah if you find out somthing please post it. I want to say thanks to all of you for the help you give!
Good luck and please post some pics when you finish the installation.
I don't know if this will help, but try visiting e90post forum. They have many 3 series owners who successfully swapped their non-projector halogen headlights to oem projector xenons.
